What Are the Different Forms and Properties of Energy?
  • Thread starter Thread starter amyheartgrl
The discussion revolves around various questions related to forms and properties of energy, including potential and kinetic energy transformations. Participants are prompted to answer multiple-choice questions about how energy changes in different scenarios, such as magnets attracting each other and a falling rock. There is a philosophical inquiry into the nature of energy and its relationship to spacetime vibrations, suggesting a deeper exploration of what energy fundamentally is. However, some participants express concern that this philosophical angle may not align with the forum's focus on physics and homework assistance. The conversation emphasizes the importance of adhering to forum guidelines and creating new threads for new questions.
amyheartgrl
Hey guys,
I have a few questions about energy. They're in multiple choice format:
1. Two magnets attract each other. How can you increase their potential energy?
A. Push them together
B. Pull them apart
C. Speed them up
D. Heat Them
E. None of the Above
2. As a falling rock hits the ground, energy is transformed from
A. PE to KE
B. KE to PE
C. KE to TE
D. PE to TE
E. None of the above
3. As a rock falls frictionlessly to earth, energy is transformed from
A. PE to KE
B. KE to PE
C. KE to TE
D. PE to TE
4. As a boy lifts the rock from the Earth again, energy is transformed from
Same possible answer choices as 2 and 3
5. Chemical energy is most closely associated with
A. Kinetic Energy
B. Gravitational potential energy
C. Elastic potential energy
D. Electric potential energy
6. Thermal Energy is
A. The potential energy stored in the molecules
B. The average kinetic energy of the molecules
C. Unrelated to the temperature of the object
D. Generated when potential energy is converted to kinetic energy without friction
Thanks very much! :smile:
You made a mighty effort in typing all that in.
thus, it shouldn't be too strenuous for you to post some of your thoughts on what the answers might be.
What does this "Potential Energy" have the potential to realize?
It has the potential to realize that if you:
B. Pull them apart
C. Speed them up
D. Heat Them
and then release them, that they'll smash into each other with more energy.
We talk about the properties which energy has and about its many forms but we never say what it is. I think that spacetime must vibrate in certain ways so as to create energy. What energy is, is then contained in a description of that vibration. Any ideas, anyone?
I think this is speculative philosophy and not suited to Physics Forums and the homework help forums in particular. Read the guidelines that you agreed to follow when you joined.
Also, new questions are often better served by creating a new thread rather than "necroposting" at the end of an old one.
