How Do Mass and Force Affect Acceleration in a Frictionless System?
  • Thread starter Thread starter jen@skywi.com
    Force Physics
In a frictionless system involving a 2kg block hanging off a table and a 3kg block on the table, the total mass of the system is 5kg. The net force acting on the system is determined by the weight of the hanging block, which is 20N (2kg x 9.8m/s²). Using the equation F=ma, the acceleration of the blocks can be calculated as 4m/s² (20N/5kg). The discussion emphasizes focusing on the forces acting on the 3kg block to simplify the problem. Understanding these principles is crucial for solving related physics problems effectively.
jen@skywi.com
A 2kg block hanging off the edge of a table pulls a 3kg block on a frictionless table. What is the mass of the system, the net force on the system, and th acceleration of the blocks.
F=ma
Not sure
20N and 30N so maybe net force 10N but not sure about the rest
Hi there,
To simplify your solution, just look at what is acting on the 3kg block on the frictionless table.
Cheers
