Physics help involving electric field charge
A proton orbits a charged sphere with a radius of 0.83 cm and a speed of 4.96 x 10^5 m/s. The discussion revolves around calculating the charge on the sphere using the relationship between electric force and centripetal force. The electric field strength at the proton's location is crucial for determining the force acting on it. The formula E = F/q is clarified, where E represents the electric field, F is the electric force, and q is the charge. The original poster successfully resolves the problem after receiving guidance on the relevant concepts.
aaronmilk3
A proton orbits just at the surface of a charged sphere of radius 0.83 cm. If the speed of the proton is 4.96 X105 m/s, what is the charge on the sphere?
proton mass = 1.67e-27
proton charge = 1.6e-19
Radius = .0083 meters
I thought maybe F = (mv²)/r
((1.67e-27)(4.96e5)²)/.0083
Then E=F/q
But this doesn't seem to be right.
Any help would be appreciated. I have tried it a couple times with no luck. Just need to get in the right direction. Thank you in advance!
What do you mean on E=F/q? What are E and q?
ehild
E = electric field
q = the charge
F = electric force
You need the charge of the sphere. If E is the electric field strength at the place of the proton, the electric force on the proton is F=eE where e is the elementary charge. How are the electric force and the centripetal force related? How do you get the electric field of the sphere?
ehild
Thanks. I figured it out.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
