Physics induction concepts help
An electric field initially points to the right near a rod, which becomes negatively charged on the left side and positively charged on the right side, generating a new electric field. This new field opposes the original electric field in direction. The discussion highlights the characteristics of electric fields created by dipoles, noting that they are not straight. Understanding the theory behind these concepts is emphasized as crucial for grasping the underlying physics. Overall, the interaction of electric fields and charges is central to the discussion.
s.bala
initally there's a electric field pointing to the right near a rod...something happens and the rod becomes negative on leftside on postive on rightside whihc supposedly generate another electric field near the rod..does this new one oppose the other one in terms of direction or make it stronger?
What are your thoughts? Electric field points from which polarity charge to which polarity charge.
Also, if the rod is has opposite charges at its ends (or on its sides?), it has an electric field for a dipole. That E-field is not straight...
this was due last week lol..ive learned the answer and the theroy behind it...its actually will oppose it
Glad that you've learned/understood the theory behind it. Berkeman was giving you another chance if you hadn't yet. We should be thankful. :smile:
