What is the maximum speed you could have and still avoid hitting the deer?
  • Thread starter Thread starter xfaceless
    Kinematics Physics
The discussion revolves around calculating the maximum speed a car can travel without hitting a deer that appears 45 meters ahead. The initial speed is 18 m/s, and the driver has a reaction time of 0.5 seconds, leading to a stopping distance of 22.5 meters after braking. For the maximum speed calculation, the total distance covered during the reaction time and braking must be less than 45 meters. A misunderstanding occurred regarding the distance available for braking after accounting for reaction time. Ultimately, the correct approach involves using kinematic equations to determine the maximum initial speed that allows for safe stopping.
xfaceless
You're driving down the highway late one night at 18m/s when a deer steps onto the road 45m in front of you. Your reaction time before stepping on the brakes is 0.50s and the maximum deceleration of your car is 12m/s^2.
a)How much distance is between you and the deer when you come to a stop?
b)What is the maximum speed you could have and still not hit the deer?
vf^2=vi^2+2ad
I figured out part a) by calculating the actual distance the deer is infront of your car (by using reaction time given), and then solved for the distance you travel after you hit the brakes using the kinematics equation.
so, the distance between you & the deer when your car comes to a stop is 22.5m.
For part b), .. I don't really understand part b). I tried solving for vi by putting vf at 0, a=-12, and d=36 but that didn't lead to the right answer. I got vi=29.4m/s which is wrong.
Any help please ? ):
Assuming the same reaction time, you can use the same equation you used in part a), but this time making the initial speed of the car an unknown. You will want the total distance traveled to be less than the 45m, so as to not hit the deer.
I think in your attempt, you assumed he was going at 18m/s in the distance covered during reaction time.
For part b) I did this..
vf^2=vi^2+2ad
0=vi^2+2(-12)(45)
vi=33m/s.
But that's incorrect..
I still dont' get it. :T
Now you're giving the car 45m of braking distance - in other words 0 reaction time. If you've got 45m total, and you travel at vi for 0.5s before decelerating, how much distance have you got for braking?
A quick sketch of velocity versus time, and distance versus time can really help to visualise this.
Nevermind. I got it.
Thanks everyone.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
