Physics. Linear Mechanics question
A physics problem involves a 5.00kg hanging block and a 3.00kg block on a table, connected by a string over a pulley, with friction affecting the sliding block. The discussion focuses on calculating the speed of the hanging block after it falls 1.50m, considering forces like tension, gravity, and friction. Participants clarify the direction of forces acting on each block and the importance of correctly labeling the masses. The calculations reveal that the acceleration cannot exceed gravitational acceleration, leading to a final result of 4.655 m/s² for acceleration. The conversation emphasizes the need for careful sign management in equations and suggests simplifying the approach by combining equations to eliminate tension.
vegetto34
A 5.00kg hanging block is connected by a string over a light pulley to a 3.00kg block that is sliding on a flat table. The coefficient of friction between the 3.00kg block and the surface is 0.400. The system starts from rest. What is the speed of the 5.00kg block when it has fallen 1.50m?
x1 = 0
x2 = 1.50m
Block 1
m1 = 5.00kg
Block 2
m2 = 3.00kg
coefficient of friction = 0.400
Block 1
x: Fnet = T1 + Tf = ma
y: Fnet = Fg + N = ma = 0
Block 2
x: Fnet = ma = 0
y: Fnet = T2 + Fg = ma = T2 - mg = ma
a = (t1 + tf) / m
a = (t2 + Fg) / m
(t1 + tf) /m = (t2 + Fg) / m
Plug block 2 (x-axis) t2 = ma + mg into block 2 equation
ma + mg + T1 = ma
mg + T1 = ma - ma = 0
T1 = -mg
I don't know if this is right. Does that mean the tension on the sliding surface is equivalent to the negative Fg?
vegetto34 said:
Block 1
Block 2
x: Fnet = ma = 0
(1) It looks like you reversed the blocks. Block 1 was the hanging block.
(2) There's only one tension in the rope; just call it T.
(3) For the sliding block, which direction do the friction and tension forces act?
(4) For the hanging block, which direction do the tension and gravity forces act?
(5) Since the masses are different, label them differently: m1 & m2.
1. Just noticed.
2. Acknowledged.
3. Friction on the sliding block acts in the opposite direction of tension.
4. Tension acts in the opposite direction of gravity.
5. Will do.
Thanks. :)
Is the distance, deltaX = 1.5, negative since the hanging block descends in height?
Thanks.
One more question. Instead of equating the acceleration of the two equations, I isolated the tension.
m1 = 5.00kg
m2 = 3.00kg
u = coefficient of friction
Block 1
T + Fg = m1*a ---> T + (-mg) = m1*a ------> T - mg = m1*a ----> T = m1*a + mg
Block 2:
T + Ff = m2*a ---> T + (-uN) = m2*a ---> T = m2*a + uN
m1*a + m1*g = m2*a + u*N
5.0*a + 5.0*(9.8) = 3.00*a + 0.400*3.00*9.8
5.00a + 49 = 3.00a + 11.76
2.00a = - 37.24
a = -18.62 m/s^2
Then plug in a into the displacement/ velocity equation: v^2 = v0^2 + 2as
Is that correct?
Thanks.
vegetto34 said:
Block 1
Careful with signs. The acceleration of block 1 will be downward, thus -a.
Block 2:
OK.
2.00a = - 37.24
a = -18.62 m/s^2
Sanity check: Compare your calculated acceleration with g. Do you think it's possible for the block to accelerate greater than g?
So it would be
Fnet = T + Fg = - ma
T + (-mg) = - ma
T - mg = - ma
T = - ma + mg
Correct?
Acceleration of Fnet cannot exceed gravity downwards, because it is the difference between Tension and Fg.
T + Fg = - m1*a ---> T + (-mg) = - m1*a ------> T - mg = - m1*a ----> T = - m1*a + mg
The result, 4.655 m/s^2.
Excellent!
Here's a tip that might make things easier (although there's nothing wrong with what you did, just personal preference): Rather than isolate T, just add the two equations to make T cancel:
(1) m1g - T = m1a
(2) T - μm2g = m2a
(1) + (2) gives:
m1g - μm2g = m1a + m2a = (m1 + m2)a
