Physics of Billiard: Understanding Angular Position & Rotation
  • Thread starter nburo
  • Tags
    Physics
In summary: I've found about this topic.In summary, the conversation discusses a problem with visualizing the motion of a cue ball on a pool table. The equations for linear and angular velocity and position are provided, along with the factors that affect the motion of the ball such as the composition of the cuestick tip and the type of surface. The main issue is the precession of the ball, which causes it to rotate with a different axis than expected. The conversation concludes with a recommendation to play pool to gain a better understanding of the practical factors that affect the motion of the cue ball.
nburo
33
First of, PhysicsForum is the best thing ever XD
Hello everyone, I'm trying to write a research paper about billiard. I've already ask a question on another thread about angular velocity and quaternions and everything worked out well. Now, I have another problem.
Let's start : There's a cue ball on the table. When I hit it with the stick, it first slides on the cloth, then, after a some time, the ball starts rolling. My problem is with the sliding part. Here's what we know :
[tex]v_r(t) = v(t) + Re_3\times\omega(t)[/tex]
That's the non-vanishing relative velocity of the contact point of the ball with the cloth (sliding movement)
[tex]v(t) = v(0) - g\mu_s \hat{v}_r(0)t[/tex]
This is the equation for linear velocity when the ball is sliding. [tex]\mu_s[/tex] is the sliding friction coefficient (if it was [tex]\mu_r[/tex], it would be the rolling friction coefficient). -g is the the well-known gravitational acceleration and v hat-r at time zero is the relative initial velocity of the ball.
[tex]\omega(t) = \omega(0) - \frac{Re_3 \times f}{I}t[/tex]
This is the angular velocity equation. R is the raduis of the ball, so [tex]Re_3[/tex] is the position of the center of mass of the ball. f is the frictional force ([tex]f = -mg\mu_s\hat{v}_r(0)[/tex] where m is the mass of the ball) and I is the inertia tensor ([tex]I = \frac{2mR^2}{5}[/tex]).
Easily, I can obtain the linear position :
[tex]p(t) = p(0) + v(0)t - \frac{g\mu_s\hat{v}_r}{2}t^2[/tex]
and the angular position of the sliding ball :
[tex]a(t) = a(0) + \omega(0)t - \frac{Re_3\times f}{2\cdot I}t^2[/tex]
These formulas work well, but for one thing : when I want to visualize those using a program, there's a problem with angular position. Here's why : if I hit the ball with a certain "top" angle with the stick, it should spin with a certain velocity in x, in y and in z (so there's a resulting axis that passes through the center of mass around which the ball should spin, let's call that axis u). The u-axis should be fixed, but, unfortunately, it appears that it is not.
I'll compare this situation to the Earth's rotation : As we know, the Earth is a pseudo-spherical rigid-body (haha). I takes one day to rotate around what we'll call the Earth's u-axis. But we also know the the u-axis also rotates. Do you see what I mean? I think this is called the "precession", it may have something to do with torque-free motion (correct me if I'm wrong).
So this is the same thing that happens to the cue ball. Instead of having a fixed u-axis, we have an axis that rotates with time : [tex]u(t)[/tex]. I'd like to find a way to relate [tex]\omega(t)[/tex] and/or [tex]p(t)[/tex] to the rotating u-axis [tex]u(t)[/tex].
Also : Do not forget that every equation works fine, the only problem is if I want to visualize in a 3D program that my colleague made. For example, if I hit the ball number 5 with the stick (with a certain "top" angle), after sliding, the "5" doesn't seem to have to right orientation and the ball doesn't even seem to spin correctly. That's why I was told by a Ph.D. that the "u-axis" might rotate too, but that it shall not affect the results, but it would be interesting to be able to visualize the motion of the ball with the program.
Finally, you may have noticed that English isn't my mother tongue. Also, I am not really advanced in physics. I know a bit more about maths, but still... not that much.
Thank you for your help, if something I said wasn't clear enough, please just tell me and I'll try to explain what I meant.
I'm afraid that I have no knowledge of math, and not much of physics. I do, however, play a fair bit of pool. There are a lot of practical factors that you aren't considering. First and foremost, probably, is the amount of follow-through on the stroke. Also, how hard the stroke is administered is important. The composition of the cuestick tip matters a great deal, as does the type of surface. 'Mercury felt', for instance, does not interact with the ball the same way that a typical 'bar table' does.
While this isn't strictly scientific, I recommend that you go out and shoot at least a dozen games per day for a while. You'll start to see things that the theories don't readily reveal. And, you'll have some fun while learning.
Thank you for your reply. I understand that there might other factors to inckude into my equations, but this only an "approximated" program. My colleague included some of the factors you described, because those were important enough to have a MAJOR modification on the velocity/position of the ball.
The only important thing here is the "precession" of the ball, that's what I'm having a problem here. Thank you for you advice, I'll surely play some games form time to time : it's so much fun!
Here guys, I found this to explain what I meant :
http://imtuoradea.ro/auo.fmte/MECANICA_files/DELIMAN%20TITUS%201.pdf
The only difference is that my ball's precession isn't caused by electrostatic effect.
Could someone help me understanding please? =)
I just noticed that the article was written in BAD English :( unfortunately
1. What is angular position in billiards?
Angular position in billiards refers to the angle at which a ball is positioned in relation to the cue ball or another ball. This angle is measured in degrees and can help determine the direction and force needed to make a successful shot.
2. How is angular position calculated in billiards?
Angular position is calculated by using trigonometry and the knowledge of geometry and angles. The angle of the cue stick in relation to the cue ball and the angle of the cue ball in relation to the target ball are both important factors in determining the angular position.
3. What is rotation in billiards?
Rotation in billiards refers to the spin or movement of a ball as it travels across the table. This spin can be created by striking the cue ball at different angles and with different levels of force, causing the ball to rotate in a specific direction.
4. How does rotation affect the movement of a ball in billiards?
Rotation can greatly affect the movement of a ball in billiards. The direction and speed of rotation can change the trajectory of the ball, causing it to curve or swerve as it travels. This can be used strategically to make difficult shots or to avoid obstacles on the table.
5. What role does physics play in billiards?
Physics plays a major role in billiards, as it helps explain the movement, spin, and collisions of the balls on the table. Understanding concepts such as momentum, friction, and angular momentum can help players make more accurate shots and improve their overall game.
  • Classical Physics
  • Classical Physics
  • Classical Physics
