What Is the Maximum Safe Depth for a Submarine with a 20 cm Window?
  • Thread starter Thread starter jason_r
    Physics
The discussion focuses on calculating the maximum safe depth for a submarine with a 20 cm window, which can withstand a force of 1.10×10^6 N. The pressure inside the submarine is maintained at 1.0 atm, while the external pressure from saltwater increases with depth. Participants discuss the correct application of the pressure equation, noting the need to convert atmospheric pressure to Pascals for accurate calculations. One user arrives at a depth of approximately 3.47 km, confirming that the pressures inside and outside the submarine can cancel each other out in the calculations. The conversation emphasizes the importance of using proper units and understanding pressure dynamics in underwater environments.
jason_r
A research submarine has a 20.0 cm-diameter window 8.90 cm thick. The manufacturer says the window can withstand forces up to 1.10×10^6 N. What is the submarine's maximum safe depth?
The pressure inside the submarine is maintained at 1.0 atm.
The sub is in salt water
Hi jason_r,
What have you tried so far?
alphysicist said:
Hi jason_r,
I''ll show you what I've got so far
please let me know if I am doing this right, because i don't have a key or anything.
thanks
P=P_o + pgh
1.10 x 10^6= 1 + (1030)(9.8)(h)
h=1.1 x 10^3m
thanks
P=P_o + pgh
There are two problems with this line. You have 1.10 x 10^6 on the left side; that is the force the window experiences, but in this equation you need the pressure that's on the window. So how can you find the pressure on the window if you know the force on the window?
Also, the first term on the right side: you seem to be saying that P_o is 1 atm, which is definitely true; however, to match the other term you need P_o to be in units of Pascals.
ok, so..
this is what i have now:
P=P_o + pgh
35014087.48=(P_o(air) - P_o(sub)) + (1030)(9.8)(h)
h=3.47 x 10^3
(does the pressure of air on top of the sea cancel the pressure of air in the sub?)
Also can you confirm that i have the correct anser?
thanks
jason_r said:
ok, so..
P=P_o + pgh
h=3.47 x 10^3
thanks
Yes, those pressures will cancel if you calculate it in one step, and that answer looks right to me. (As long as you have the right value for the density of seawater.)
k thnx
