How Long to Heat Ammonia Gas by 12°C with Solar Power?
To determine the time required to heat 200 kg of ammonia gas by 12°C using solar radiation of 600 W, the specific heat capacity of ammonia at constant volume is needed. The total energy required can be calculated using the formula Q = mcΔT, where m is the mass, c is the specific heat capacity, and ΔT is the temperature change. The energy provided by the solar radiation over time can be expressed as E = P*t, where P is power and t is time. By equating the energy required to the energy provided, the time can be solved. The discussion emphasizes the need to calculate the number of moles of ammonia and its molar heat capacity for accurate results.
cash.money
The sun heats 2.00 x 10^2 kg of ammonia gas that is kept at constant volume in a large tank. Assuming that solar radiation of 6.00 x 10^2 W caused the heating, determine the length of time it took to raise the ammonia's temperature by 12°C.
You will have to show us what you have done. How many moles of ammonia do you have? What is the molar heat capacity of ammonia gas at constant volume?
AM
TL;DR Summary: Find Electric field due to charges between 2 parallel infinite planes using Gauss law at any point Here's the diagram. We have a uniform p (rho) density of charges between 2 infinite planes in the cartesian coordinates system. I used a cube of thickness a that spans from z=-a/2 to z=a/2 as a Gaussian surface, each side of the cube has area A. I know that the field depends only on z since there is translational invariance in x and y directions because the planes are...
