Calculating Speed: Solving a Physics Wave Question | Homework Help
  • Thread starter Thread starter roxxyroxx
    Physics Wave
The problem involves a cyclist and a car approaching each other, with the car emitting a sound at 500 Hz, which the cyclist hears as 535 Hz. The correct approach to solve for their speeds requires using the general Doppler effect formula, as both the source and receiver are in motion. The attempted solution incorrectly applied a simplified formula, leading to an incorrect speed calculation of 22.4 m/s instead of the correct 11 m/s. By applying the appropriate Doppler formula, the velocities of both the cyclist and car can be accurately determined. The final result indicates their speed is approximately 11.6 m/s.
roxxyroxx
a cyclist and a car are approaching each other at the same speed. the car makes a 500 Hz sound at 343 m/s. the cyclist hears the sound as 535 Hz. How fast are they moving?
f2 = f1(v/v\pmvs)
535 hz = 500 hz(343 m/s\div343 m/s-vs)
vs = 22.4 m/s
but the answer should be 11 m/s
HELP ??
In this case, both the source and the receiver move, so u must use the general Dopple formula, not the specific formula for each case the source moves or the receiver moves.
f' = f.(V+Vr)/(V-Vs)
f': frequency received
f: frequency created.
V: speed of the wave (sound or light).
Vr: velocity of the receiver: positive if moving toward the source, otherwise it's negative.
Vs: velocity of the source: positive if moving toward the receiver, otherwise it's negative.
In this case, Vs=Vr, and they're both positive. U will get the result 11,6 m/s. Be happy :D
great thanks!
