How does the design of piano strings and the use of hitch pins affect tuning?
In summary: in summary, the notes on a piano can be tuned by adjusting the tension on the rightmost string of the note. this string loops around a metal peg, and the tension can be as high as 150 lbs. depending on the string, the center string, or delimiter, the frequency will be determined.
physicsisphirst
233
ok certain notes have 3 strings.
the rightmost string of a note loops around a peg and becomes the leftmost string of the next higher note.
so if you increase the tension on the first, you have to increase the tension on the adjacent. right?
well i thought so too, yet I've had 2 piano tuners tell me that this isn't so - that the tightening the rightmost string on a B does not affect the tension on the adjacent C's leftmost string.
they laugh at me saying that if it were so then it would be impossible to tune the piano.
i tell them that the tuning can come from the length of the delimiters on the string and that may be the 'shared' string idea was done to actually speed up tuning - ie by tuning the rightmost string on the B, you automatically end up with the correct tension for the adjacent C's leftmost string (the delimiters end up giving you the correct pitch when the tension is correct).
i figured my understanding needs to be ratified or corrected so i brought my question here. besides, i don't want to be laughed at anymore. :cry:
in friendship,
prad
I'm guessing that the thickness and tension properties of the wire isn't consistent enough to accurately tune a piano. If it is just one continuous wire, somehow there's something to take up the slack between adjacent runs of the wire.
Depending on the way that the string is looped, you might find that the amount of friction is so large that you could consider it to be attached in a fixed fashion instead.
It may also be that the two strings should be at the same note since there is some black magic with blending to make the well-tempered klavier sound right.
the string simply goes around a smooth metal peg and we are looking at tensions of around 150 lbs and over from what i read on the net.
even if the string were looped around the peg and even if the peg had rough contact points, i don't see how the friction could be great enough to not cause even distribution of the tension between the 2 segments of string.
in friendship,
prad
Have you looked at the other (non-adjustable) end of the frame holding the strings? Maybe the setup there prevents the strings from sliding.
well the string goes from the tuning key around a peg and then to another tuning key.
here is the order for a sequence:
leftmost string for second highest G wraps around the peg and becomes middle string for the same note. then the rightmost string for that G wraps around the next peg and becomes the leftmost string for G#.
the middle string for G# wraps around a peg and becomes the rightmost string for the same G#.
then we start the sequence again with A's leftmost string becoming the same as its middle string. but A's rightmost string goes around the peg and becomes A#'s leftmost string.
the pegs are simply smooth pieces of metal.
in friendship,
prad
I did a web search on this, and some strings do affect two adjacent notes. I'm not sure how this is handled. Note that the center strings don't have this issue, and these are tuned first.
thanks for looking, jeff.
i think the delimiters that end up determining the actual length of the struck string decide the frequency it will vibrate at. so you can have 2 strings at the same tension, but because the delimiters create different lengths, you can get different notes.
in friendship,
prad
prad,
the "delimiter" that you mentioned creates a "center node", that in effect, creates 2 separate strings (standing wave). each one is a different length, mass, and tension, which are the 3 inputs you need to determine frequency. f=1/L x sqrt T/(m/L). as long as the center node creates the right ratio of lengths, the right ratio of frequencies will be produced. to go down an octave and a step (G' to G#), the length of the shorter run would be 1/2 the longer run /1.05946 (the 12the root of 2). the "slack" in the longer can be played with (tuned) to a great degree (more than nec. for tuning) before the shorter will slip off the node. now, I've never seen the inside of a piano, but i doubt you'll get a better answer from the piano tuners. :rolleyes:
TRoc
T.Roc said:
prad,
TRoc
thank you very much troc!
i am confused about one thing though - by delimiter i mean the 2 points that establish the actual length of the struck string - i don't mean the peg that the string goes around.
i can see how the peg would create 2 strings being a node, but i don't see how the delimiters could do this:
-------------^-------------------------------^------------------------- string
the 'carats' are the delimiters and appear under the string.
here is the top view:
/ -----------^-----------------------^---------- to tuning key
|O
\ ----------^-------------------------^-------- to tuning key
the peg is the O and the string wraps around that.
my contention is that given that the tension is around 150 lbs or more and that the peg is friction-free, there is no way you can avoid that tension being equally spread between the 'two' strings (because they are in reality one string).
in friendship,
prad
prad,
i believe, in the world of physics, "friction free" may not be accurate (especially under 150 lbs tension). again, not having seen in a piano, I'm not sure, but are the strings "wound" (like a bass string)? if so, then it would be like a metal file against the peg. that failing, then consider this: the co-efficiency of friction on a polished DRY marble floor is higher than that of a textured surface because, at the microscopic level, there is more surface area to act upon. the tension on the longer string is less, and has slack. the act of finding the correct frequency could be described as logarithmic. the distance of the string is changed by the gear in the tuning peg, which changes in steps defined by the gear size. often this is too much, and you have to back off and come back to "in tune". if you marked control lines on the tuner peg and instrument, they would not be aligned from one days' tuning and the next. temperature, and age of the strings also play a role in this "floating" tuning point.
best regards,
TRoc
i agree that it wouldn't be friction-free by any means. yet it seems to me that even if the string was wound like a bass string (and the higher ones aren't), that the increase in the coefficient of friction wouldn't be sufficiently great to offset an even distribution of the tension especically when you consider the small surface area of contact between the peg and the string. overtime (if not immediately), i would think there would have to be slipage at the peg evening out any tension discrepancies.
i suppose one way to find out is to put my own delimiters fairly near to the peg at an equal distance and see if the pitch is the same on each adjacent string.
in friendship,
prad
prad,
i think the bottom line is that, if the long side is in tune, the short side must be in tune too. the slack in the long side presents the easiest way for the tension to change. you would have to take the long side up to a full octave (or more) above the short side before the tensions on both sides were = enough to slip on the peg. if you want to experiment, use a rubber band set up in the same fashion.
TRoc
Prad:
Is the distance from one tuner to the peg different than the distance from the other tuner to the peg? If so, the system may in fact be designed to slip.
My practical experience with strings is limited to the guitar, but I have learned a good deal of the theory along the way. Given a certain set of environmental conditions, the pitch produced by a string is a function of it's composition, thickness, tension, and length. On a standard guitar, the overall length of the strings is ~25 inches. If you shorten the string by a certain distance (by pressing down on on a fret) the pitch rises by a certain number of steps. For example, if a string is tuned to 'C' and I press down on the first fret (shortening the string by x inches), I get a C#. If I retune the string to D (increasing the tension) and press down on the first fret, I get a D#. The difference between the 2 notes remains the same.
The point I'm trying to make is that if the 2 sides have the approprate ratio of lengths and slip freely around the peg, then having one side in tune means that the other *should* be in tune. The only way I could see them not being in tune in this set up would be something physically wrong (bent tuner, damaged string, etc.)
In any case, it should be relatively easy to check whether the string slips or not. Tune 1 side to the correct pitch and check the pitch on the other side. Note the results and then tune the same side down 1 step (from D to C for example) and check both sides with the tuner. If both sides drop equally (D & D# drop to C and C#), then it's safe to say the strings slip freely over the peg. If they *don't* change relatively, then you'll obviously have to tune each side separately.
exactly! that's how i see it too and what makes both sides in tune is the separation of the delimiters and the fact that the tension is the same on 'both' strings.
anyway, i greatly appreciate your inputs Grogs and TRoc (as well as the others).
thank you all!
in friendship,
prad
Stumbled across this (old) thread and thought I'd comment based on both my physics and piano restoration background:
There is sufficient friction on the hitch pin ("peg") to prevent slippage under normal circumstances- therefore the two halves of the string can be under different tensions. String tensions within a note are designed to be the same hence there is very little differential tension either side of the hitch pin. Tensions between adjacent notes should also be similar, although there is a gradual grading of tension across the scale with the bass section being around 20% higher than the treble. Some piano scales are more even than others. So there will typically be some variation in tension note to note although the difference is small enough not to cause slippage.
If there were to be slippage at the hitch pin then the piano would indeed be untunable - particularly with the strings that are shared between notes.
Wrt the discussion on "delimiters" - the critical length is the so-called speaking length which is defined by the "v-bar" up near the tuning pins and the bridge pins - ie the pins on the wooden strip that connects to the soundboard. This is the only length that is intended to vibrate. The frequency of vibration is defined by this length, as well of course by tension and the wire mass. The short length between the bridge and the hitch pin would tend to vibrate at a higher frequency than the speaking length. This is an unwanted vibration that is suppressed by a felt strip or similar means ( although in some grand pianos (such as Steinway) this length is tuned by moveable terminations and allowed to vibrate symathetically - the so-called Duplex scale)
Note that each (half) string is under uniform tension over its entire length from the tuning pin to the hitch pin.
Looped stringing is common to most pianos. It simplifies the stringing process - avoiding the need for a lot of hitch pins and the need to terminate each string in an eye.
A few top brands use non-looped stringing but it is the exception rather than the rule. The main advantage is that if a string breaks then you only lose one, rather than two (complete loss of tension on one half will indeed cause slippage! )
Hope this gives some insight!
Cheers,
Graeme
I suggest you actually look at a piano carefully, rather than reading about them on the web.
You will see that the way the string is held is DESIGNED to create a lot of friction! It doesn't just go round the tuning pins and the hitch pin at the other end. There are also pins (more than one at each end) where it goes over the bridges, and there are metal plates (called "agraffes") that press down on the non-playing parts of the strings to create more friction.
Your piano tuners are quite right, in practice the two parts of the string can be tuned completely independently. However there is some skill involved in getting all the parts of ONE half of the string to be at the same tension, because of the amount of friction. It ain't as simple as just turning the tuning pin. That's the usual reason for a piano to go out of tune quickly - i.e. it wasn't tuned properly in the first place.
Piano wires are usually stressed right up to the limit where they begin to go plastic. The average tension in each "string" of a grand piano is of the order of 150 to 200 pounds force. The forces in guitar strings are way lower than that, so any analogies about tuning, or friction, are most likely to be misleading.
In truth the only parts designed to provide friction on a piano string are the hitch pin and the tuning pin. Any other points of friction are unintentional. The agraffes or v-bar and the bridge pins are most definitely not intentionally designed to provide friction - rather they purely provide the termination points that define the speaking length of the string. In fact many bridges are coated with graphite to improve the slippage of the string over them.
The string tension equalizes over its length. During tuning, when the tension of the string is changed, there is a transient differential in tension - the tension between the tuning pin and the v-bar (or agraffe) is slightly higher than the remainder of the string, if the string is being pulled up to pitch, due to friction at the v-bar . This is the reason that the tuner strikes the note loudly - the mechanical shock helps to release the binding at the v-bar and hence equalize the tension across the string.
If this is not done then the string can subsequently go out of tune. The other main cause of the piano going out of tune shortly after tuning is if the torsion on the tuning pin introduced during tuning isn't neutralized by applying a slight reverse torque on the pin as the final stage of tuning.
The maximum difference in tension on the two sides of the hitch pin can be estimated by the standard "capstan equation" which is derived from Coulomb friction for a rope wrapped round a circular object. The ratio of tensions between the two ends of the rope when slipping occurs is
[tex]T_2 = T_1 e^{\mu \theta}[/tex]
where mu is the friction coefficient and theta is the wrap angle (in radians).
For a hitchpin the angle is pi radians. For a typical metal-on-metal friction coefficient of 0.1 that means the possible difference in tensions on each side is 37%. A friction coefficient of about 0.036 would hold the 12% difference in tension needed to tune two equal length strings a semitone apart (6% difference in pitch). In practice the strings are not equal length, so an even lower friction coefficent would be enough to do the job.
I agree with the last two posts. Having tuned many pianos, it is certainly possible to tune two halves of the same string at significantly different pitches. The only time you have a problem is when there is you let the tension in one string go too low, as this will lower the tension of the adjacent half that you may have just tuned. If you are raising the pitch of an old piano, you have to do a rough tuneup to raise the pitch and then retune. It can take several tunings to become stable.
The best grand pianos have a single strings and avoid this problem entirely.
AM
Thanks AlephZero for providing the theoretical explanation.
As you correctly indicate there is also little tension difference note to note - the scale design of the piano is arranged such that the tension is virtually the same note to note albeit with a gradual increase in tension going down the scale. The variation in pitch from note to note is therefore achieved predominately by a change in speaking length and also by a variation in wire gauge (increasing diameter going down the scale) rather than a change in tension.
The process of tuning can therefore be considered as bringing the strings to more or less a uniform tension.
With regard to bringing a badly out of tune piano up to pitch - the need for multiple tunings to do this is predominantly due to the finite compliance of the iron frame and of the soundboard rather that string slippage. By the time you finish tuning the last note you will find that the rest of the piano has gone out of tune - ie flat but not as flat as it was originally. This is because the overall increase in tension has caused the frame to compress slightly and the soundboard - which is crowned and presents an upward force on the strings at the bridge - to flatten somewhat. Because the stretch on a piano string from no tension to its intended tension is only a few mm it doesn't take much compression of the frame - ie a fraction of a mm - to put it out of tune.
Pianos with a so-called barless construction - ie. absence of a treble frame bar - are the worst in this regard.
New here. So when going from one frequency using three strings to display the note what happens if the string diameter is reduced by half a size so we would have for example a string over a pin size 15.5 for two and the left side of a size 16 all three tensioned to produce the required frequency. Does that fly? and even if it does will the change in diameter of the string have an impact on the harmonics such that the one diameter is unhappy with the other.
For the same frequency of tuning, and the same amplitude, the string diameter changes the energy stored in the string. If the main energy loses come from radiated sound, a thing string will dampen faster than a thick one. It does not change the harmonics content.
The harmonic content is mainly determined by the place and the way that the string is excited. Compare sounds of piano and harpsichord.
There is some influence in harmonics which comes from the stiffness of the string. Steel strings are richer in high harmonics than classic strings.
With the trichords (3 string notes) there is never a change of wire gauge within a note. With looped stringing two adjacent trichords will consume (exactly) 3 loops. Therefore gauge changes occur at most every 2 notes. Most often in fact there are 4 or 6 notes of the same gauge.
The harmonic character of a piano is due to a number of factors - the elastic properties of the hammer, the point at which the string is struck (usually around 1/7th of its length), the coupling impedance to the soundboard, the properties of the string including its tension per se and its tension in relation to its elastic limit etc etc.
The finite diameter of the string in relation to its length (stiffness/bar effect) produces a non-mathematiclly exact harmonic series - the harmonics are slightly sharp relative to a mathematically pure series (ie the integer multiples of the fundamental frequency). This effect is termed inharmonicity. A degree of inharmonicity is desirable as it gives the instrument character - however particluarly in smaller upright pianos the amount of inharmonicity is greater than optimal owing to the highly foreshortened string length - particulary in the bass - which is one of the reasons a small piano sounds inferior to a large grand.
Piano wire is made of steel and is very stiff. The thickness of a piano wire is also much greater than a guitar string and is more characteristic of a rod than a string. The bend in the wire at the point where it goes around the hitch pin in addition to friction negates slippage for the difference in tension sufficient to allow both halves to be tuned individually to a relatively close pitch.
Scaling the speaking length from note to note allows for both halves of the piano wire to have nearly identical tensions when in tune so that the potential for slippage around the hitch pin is further reduced.
The precision required for a fine tuning is within one hundredth of a semitone so that attempting to tune both halves of a piano wire from one end would be nearly impossible, even with a "frictionless" hitch pin. The wire is just to stiff and producing a stringing scale of the required precision is not necessary if at all possible.
1. What is the "piano string tuning dilemma?"
The piano string tuning dilemma refers to the challenge of tuning the strings of a piano to the correct pitch and maintaining that pitch over time. Due to the tension and wear on the strings, pianos require frequent tuning to stay in tune.
2. Why is piano string tuning important?
Piano string tuning is important because it affects the overall sound and quality of the instrument. A piano that is out of tune will sound dissonant and unpleasant to listen to. Proper tuning also ensures that the keys and notes are in the correct pitch, allowing for accurate playing and performance.
3. How often should a piano be tuned?
A piano should be tuned at least twice a year, but it is recommended to have it tuned every 6-12 months. However, pianos that are frequently used or located in environments with extreme temperature or humidity changes may require more frequent tuning.
4. Can I tune my own piano strings?
While it is possible to tune piano strings yourself, it is not recommended unless you have proper training and experience. Piano tuning requires specialized tools and knowledge of how to adjust the tension on the strings to achieve the correct pitch. It is best to leave piano string tuning to a professional technician.
5. How long does it take to tune a piano's strings?
The time it takes to tune a piano's strings can vary depending on the condition of the piano and the skill of the technician. On average, it can take 1-2 hours to tune a piano, but it may take longer if the instrument has not been tuned in a long time or if there are significant issues with the strings or other components.
  • Other Physics Topics
10K
  • Mechanical Engineering
15K
10K
