Pile Driver Energy Homework: Calculate Change in PE
  • Thread starter AutumnBeds
  • Tags
    Energy
In summary, the pile driver with a mass of 220 kg falls from rest through a distance of 1.8m onto a 380 kg concrete pile, driving it into the ground by 200 mm. The total distance traveled by the driver and pile combination is 0.2m. Using the principle of conservation of energy, the change in potential energy for the driver and pile combination is calculated to be approximately 1177.2 joules.
AutumnBeds
A pile driver of mass 220 kg is allowed to fall from rest through a distance of 1.8m on to a 380 kg concrete pile to drive it into the ground. Each impact drives the pile into the ground by 200 mm. Assuming that the pile driver remains in contact with the pile after impact and that momentum is conserved, use the principle of
conservation of energy to calculate
b. The change in potential energy of the driver and pile combination on moving into the ground.
b. Conversion of potential energy into kinetic energy
No attempt made as of yet as I am struggling to understand the question.
I am assuming that tp work this out two parts are required;
Fist calculate potential energy for driver = 220*9.81*1.8 = 3884.76 joules
Then calculate potential energy of the pile - which is either= 380*9.81*-20 or 380*9.81*20 (I am unsure of the 20mm if it easier positive or negative with being driven into the ground, but the direction of force is the same)
Then calculate the difference and convert to kinetic energy.
Any help would be really appreciated. I am not looking for the exact workings out, but a point in the right direction.
Thanks in advance!
The question only asks about the change in potential energy for the driver and pile combination. Presumably that means when they are together and moving as one. So, what potential energy do you think they have in mind?
If they are moving as one, they would have a total mass of 500kg and moved a total of 2m.
so, MGH = 500x2x9.81 = 9810 joules
2 m is not right: that would include the distance that the driver falls before it makes contact with the pile. How far do they move while they are together?
Ah ok, if so would the total distance only be 0.2m?
Giving = MGH = 500*0.2*9.81 = 981 joules
Yes.
Check your mass sum. 220 + 380 = ?
Thanks!
1177.2 joules
1. How is potential energy calculated for a pile driver?
Potential energy for a pile driver can be calculated using the formula PE = mgh, where m is the mass of the pile, g is the acceleration due to gravity, and h is the height of the pile.
2. What is the change in potential energy for a pile driver?
The change in potential energy for a pile driver is equal to the difference between the final potential energy and the initial potential energy.
3. How does the height of the pile affect the potential energy of a pile driver?
The potential energy of a pile driver is directly proportional to the height of the pile. As the height increases, so does the potential energy.
4. Can potential energy be negative for a pile driver?
No, potential energy cannot be negative for a pile driver. It is always a positive value as it represents the amount of energy stored in the system.
5. Is potential energy the only factor that affects the efficiency of a pile driver?
No, potential energy is not the only factor that affects the efficiency of a pile driver. Other factors such as the mass and velocity of the pile, as well as external factors like friction, can also impact the efficiency of a pile driver.
16K
