Designing a Hartnell Governor: Understanding the Use of Pins and Bosses
  • Thread starter Thread starter RKD89
The discussion focuses on designing a Hartnell governor, specifically regarding the function and definition of 'boss' in relation to pin joints. A 'boss' is identified as a thickened area of material around an attachment point, typically seen in cast components. There is also a query about whether the fulcrum arm should have a forked design at the fulcrum pin or maintain a standard configuration with the lever arm. Clarification on the second question is pending as participants seek to understand the design implications better. Overall, the conversation emphasizes the technical aspects of joint design in mechanical systems.
RKD89
I m designing a hartnell governor as a mini machine elements design project( don't as why)
While designing the pin joints for the levers at the point of pivot ( fulcrum point as shown in fig),I came across something known as 'boss'.
Is it the enlarged portion of the lever itself that comes in contact with the pin or something like a bush/bearing that comes in between the pin and the lever?
Secondly:
The lever arm will have a fork-ed end at the end where lever is attached to the roller on sleeve.
Should the fulcrum arm( attached to the body/casing ) be also forked at the fulcrum pin or should fulcrum arm at one end and lever arm at other end of fulcrum pin as shown in figure ??
PS: I know I haven't really named pins in the diagram, but guess u guys can Easily understand it
In my experience, "boss" refers to a thickening of material around an attachment point. This is most evident in cast pieces wherein there is a bit of a "tower" where bolts are to be inserted.
I'm having a wee bit of trouble following your second question, but I''ll try to catch up on it later.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
