Placing a pole with maximal radius subject to constraints
The discussion revolves around optimizing the placement of a smaller circle within a defined area constrained by a larger circle and a square. The user seeks to maximize the radius of the smaller circle while adhering to specific geometric constraints involving angles and distances from lines. They express uncertainty about the existence of a closed-form solution and inquire about optimization tools or alternative solving methods. A key insight is that the smaller circle will touch both the edge of the square and the arm at a 45-degree angle. The thread highlights the mathematical relationships and calculations involved in determining the optimal radius.
GuyWhoOnceToldYou
TL;DR Summary
Looking to place a pole with maximal radius, constrained by objects surrounding it
I have a problem that I imagine does not have a closed-form solution and requires the use of some kind of optimization solver. I am not an engineer myself, so forgive me if the question seems stupid.
The problem is as follows: I have a circle bound in a square, and an arm going from the center of the circle to the corner of the square (so, 45 degrees), and I need to place a circle with the largest radius possible in the area bound between the outside of the big circle, the inside of the square, and below the arm (the area in green in the image)
I can describe these constraints mathematically: I want to maximize some r subject to the constraints: let 2*w be the total width of the arm, and r_circle be the radius of the black circle, then the constraints are:
(r+r_circle)*(cos(alpha),sin(alpha)) is at least distance w+r from the line y=x (I can directly calculate the closest point on the line as a function of r and alpha to simplify this one, I just haven't done that yet).
(r+r_circle)*(cos(alpha),sin(alpha)) is at least distance r from the line from the line x=r_circle (the right edge of the square) (again, I can calculate the point as a function of r, alpha directly)
alpha is between 0 and 45 degrees
So what I'm looking for is either (A) a better way to solve this, or (B) a tool that can solve this.
Thanks in advance!
Where the big circle has radius R;
The small circle will have a radius; r = R * 0.123308641756286
R = 1.
Small circle centred at x = 1 - r ; y = x - r * Sqrt(2)
Distance between centres d = Sqrt( x*x + y*y ) ;
Find r, for d - r = 1 ;
Likes DeBangis21 and GuyWhoOnceToldYou
Of course! I can assume the resulting circle will touch both x=1 and the arm at 45 degrees, that didn't occur to me. Thank you! I will have to adjust to account for the width of the arm, but I think that would be easy.
Welcome to PF.
0.123308641756286 = 1 / ( 3 + √2 + 2*√( 2 + √2 ) )
0.123308641756286 = 5 - 3*√2 - 2*√( 10 - 7*√2 )
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
