Planck's Law Problem: Solve for Vmax 3 Sig Digits
In summary, the conversation discusses finding the frequency (Vmax) at which energy density is at a maximum using Planck's Radiation Formula. The solution requires simple calculus and numerical methods, specifically solving a transcendental equation. The equation is derived and simplified to Vh/(3kT)=[1 - 1/ (e^(hv/kT))], where the constant x represents hv/kT. The conversation also mentions the use of the series expansion for e^x to solve the equation numerically.
nadeemo
Given Planck's Radiation Formula
Find the frequency (Vmax) at which energy density is at a maximum. This requires simple calculus and numerical solution of a simple transcendental equation.
You only need to find the answer to 3 significant digits.
So i derived the equation and set it equal to 0 and i got
V = [3kT / h][1 - 1/ (e^(hv/kT))]
But i can't seem to finish it because of the V in the exp...
also we know that
e^x = 1 + x + x^2/2! + x^3/3!+ ... and that somehow has to play a role in solving this...I think...
You have to do this numerically. Call hv/kT=X. Then your last equation is X/3=1-e^(-X). Write this as f(X)=1-X/3-e^(-X). You want to solve f(X)=0. Plot it. For values of X around 1 f(X) is positive, for values around 4 it's negative. So there must be a root in between. You could just solve it by bisection.
x/3 = 1 - e^(-x)
why is it 'x/3' ?, and not just x
nadeemo said:
x/3 = 1 - e^(-x)
Because you have 3kT/h. Note the '3'.
wont it be 3x/v ??
since we have
hv / kt = x
andd in this part we have
3h/kt...wont that equal 3x / v
nadeemo said:
wont it be 3x/v ??
since we have
hv / kt = x
Yes. And 3kt/h=3v/x. ?
hv / Kt = x
kt/hv = 1/x
3kt/hv = 3/x
3kt/h = 3v/ x
...i still don't understand where you get "x/3" from, please clarify
You had:
this is the same as:
Vh/(3kT)=x/3.
1. What is Planck's Law and why is it important in science?
Planck's Law is a fundamental law in physics that describes the relationship between the energy of a photon and its wavelength. It is important because it helps us understand the behavior of light and radiation, which has implications in various fields such as astrophysics, quantum mechanics, and thermodynamics.
2. How do you solve for Vmax with 3 significant digits using Planck's Law?
To solve for Vmax, you will need to use the formula Vmax = 2.82kT/h, where k is the Boltzmann constant, T is the temperature in Kelvin, and h is Planck's constant. First, plug in the values for k, T, and h, making sure to use the appropriate units. Then, calculate the answer and round it to 3 significant digits.
3. What are the units for Vmax in Planck's Law?
Vmax has units of meters per second (m/s) in Planck's Law. This represents the maximum speed of a photon at a given temperature, which is the point where the photon has the most energy.
4. Can Planck's Law be applied to all types of radiation?
Yes, Planck's Law can be applied to all types of radiation, including electromagnetic radiation and thermal radiation. This is because the law describes the behavior of photons, which are the fundamental particles of light and radiation.
5. How does Planck's Law relate to the study of blackbody radiation?
Planck's Law is closely related to the study of blackbody radiation, which is the radiation emitted by an object at a given temperature. The law helps us understand the intensity and distribution of this radiation, and it also allows us to calculate important parameters such as the peak wavelength and total energy emitted by a blackbody.
10K
