Plane & 3D Vector Homework Solution
  • Thread starter Thread starter lpbg
    3d Plane Vector
The discussion focuses on solving a homework problem involving a straight line and its intersections with various planes. The line's equation is given, and the first task is to find point A, the intersection with the yz-plane, which is determined to be at t=-3/2, resulting in coordinates A(0,1,1/3). The next steps involve re-parametrizing the line to create a unit direction vector and ensuring that as the new parameter u increases, the x-coordinate also increases. Participants express confusion about how to apply the unit vector formula and the implications of the direction of travel for the line. Clarification is sought on how to properly adjust the direction vector to meet the problem's requirements.
lpbg
problem 1:
given the straight line r whose equation is r=<3+2t, 4+2t, -1-t>
0.Determine A, intersection of the plane yz
0.1the parameter value at A is t=
0.2therefore A=(...,...,...)
1.we want to re-parametrize r (be u the new parameter) so that:
1.1the new direction vector e be a unit vector, then e = <...,...,...>
1.2 as u increases the x coordinates increases. it follows that e=<...,...,...>
1.3 A be the new origin point. the new equation is: r=<...,...,...>
2. Determine B and C, intersections of r with the zx and xy plane respectively.
2.1 parameter values at the two points are Ub=... Uc=...
2.2 distances AB and AC are therefore dAB=... dAC=...
2.3 Points coordinates are B= (...,...,...) C=(...,...,...)
A at x=0 hence 3+2t=0 therefore A at t=-3/2
point A(0,1,1/3)
direction vector d=(2,2,-1)
for 1.1 the formula to be applied is v/|v| but i don't know whether it should be applied to the direction vector or to the original equation. also question 1.2 is problematic for me since i don't understand what is asked for. any help is much appreciated
For 1.1, if t increases, in what direction does the point r(t) travel? They want a unit vector in this direction.
For 1.2, you may need to flip that vector around so that it points toward the positive x axis.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
