Plane landing, finding the velocity
  • Thread starter Thread starter albertnewton
    Plane Velocity
A plane is approaching a runway at a 15-degree angle below horizontal, with a constant speed denoted as v0. The radar measures the distance r and angle theta, where r(dot) is 216 ft/s and theta(dot) is -0.022 rad/s when theta is 20 degrees. The discussion focuses on converting the velocity vector v0 into its components using the given angles and rates of change, but confusion arises regarding the correct angles and units. Participants emphasize the need for a drawing to clarify the relationships between the variables and to correctly apply trigonometric functions. The conversation highlights the challenges of solving for v0 and r without knowing the exact distance r, indicating that further calculations are necessary.
albertnewton
A plane, B, is approaching a runway along a straight line 15 degrees (angle phi) below horizontal, while the radar antenna, A, is monitoring the distance, r, between A and B, as well as the angle between A and b, theta. The plane has a constant approach speed v0. In addition, when theta=20 degrees, it is known that r(dot)=216 ft/s and theta(dot)=-0.022 rad/s. Determine the corresponding values of v0 and of the distance between the plane and the radar antenna.
Phi=15 degrees
Theta=20 degrees
r(dot)=216 ft/s
theta(dot)= -0.022 rad/s
Since v is constant, a=0.
a=dv/dt
v=ds/dt
I tried solving knowing that a=0. However, I do not know how to utilize the r(dot) and theta(dot).
This is more math than physics. You already have a = 0 because v0 is constant.
You aren't interested in he trajectory of the plane, only in the components of the vector v0,
for which you were given the angle w.r.t. horizontal.
All you have to do is convert the vector v0 to dr/dt and dtheta/dt. Or rather the other way around.
Make a drawing showing A, B and vector v0.
I hope the radar is between the plane and the runway...
The radar is between the runway and the plane. So when I convert v0 to dr/dt and dtheta/dt would it look like this:
v0=cos(35+15)*dr/dt - cos(90-50)*dtheta/dt
v0=cos(50)*(216 ft/s) - cos(40)*(-0.022 rad/s)
if so I don't know r so I can't convert rad/s to ft/s in order to simplify?
You also know the direction of v0. That should give you a second equation. Did you make the drawing ?
Reason I ask is because I don't see where the 35 degrees comes in.
Bedtime for me. make the drawing. Project v0 on the r vector and on the theta direction.
Yes, v0 has a component in the u_r direction (x component) and in the u_theta direction (y direction). Here's what I did but it is not correct:
v0 = (216)(cos(35)) + (-0.022)(sin(35)) = 176.949
obviously this is wrong because the -.022 is in units rad/s and I am not sure how to convert to ft/s unless in know r.
it should have been cos(20+15) not cos(35+15).. stupid error
Don't forget to correct your conversion formula: you want ft/s in the second term, not radians/s
Do these flying folks still use feet/s ? ;-)
Still don't see where the addition of the angles comes from. The plane was landing, wasn't it ?
Suppose it was flying straight at the radar. Would you calculate with 20 degrees + 20 degrees ?
r is an unknown, so you have to leave it in.
I really have to turn in now. If your drawing doesn't help you out, a different tack is to convert v0 to a horizontal and a vertical component, and then do the same with v(r, theta) = (vr, vtheta) theta = 20 deg, r is unknown.
