What is the minimum height for a mirror to see full image?
  • Thread starter Thread starter Dars
    Mirror Plane
To see a full image in a mirror, the minimum height of the mirror should be half the height of the person, which is 1 meter for a 2-meter tall individual. This is because a plane mirror reflects light at equal angles, allowing the viewer to see their full reflection without needing the mirror to be the same height as themselves. Drawing a ray diagram can clarify how light reflects and aids in understanding the concept better. Many participants in the discussion emphasize the importance of visual aids in solving this problem. A proper understanding of reflection principles is essential for determining the minimum mirror height.
Dars
I am 2 meters tall and I want to see my full image in a mirror. What is the minimum height the mirror should be?
Why shouldn't min height be also 2m, because no magnification (plane mirror) ??
Here, drawing a ray diagram would really help, because I have seen a lot of confusion among guys about this question... so draw the RD and post it here, and believe me, it helps a lot.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
