Plane where clocks are synchronized in both frames
The discussion centers on finding the velocity of a plane where clocks in two different frames are synchronized using Lorentz transformations. An initial attempt yielded an incorrect solution due to the use of the wrong form of the transformations. The correct transformations are t' = γ(t + vx/(c^2)) and x' = γ(x + vt), which lead to the accurate solution of v(t = t') = (c^2)/v * (1 - 1/γ). The user resolved the issue and clarified the correct approach to synchronize clocks in different frames. This highlights the importance of using the correct equations in relativistic physics.
LoadedAnvils
What is the velocity of the plane where clocks in two different frames are synchronized?
Lorentz Transformations:
t' = γ(t - vx/(c^2))
x' = γ(x - vt)
Solution should be v(t = t') = (c^2)/v * (1 - 1/γ)
I am getting the negative of the solution: v(t = t') = (c^2)/v * (1/γ - 1)
If I contract to the frame of the plane, I get that
γ_p(t - (v(t = t')/c^2)x) = γ_p(t' - (v(t = t')/c^2)x')
Simplifying and solving for v(t = t'), I get
v(t = t') = (c^2)(t - t')/(x -x')
Transforming t' to t and x, I get
v(t = t') = (c^2)(t - γt + γ(v/c^2)x)/(x - γx + γvt)
Dividing through by t on both numerator and denominator and noting that x/t = 0, I get
v(t = t') = (c^2)(1 - γ)/(γv)
Which leads to the solution I obtained.
EDIT: Never mind, I figured it out. I used the wrong form of the Lorentz transformation.
If anyone is interested, it's supposed to be t' = γ(t + vx/(c^2)) and x' = γ(x + vt)
instead of t' = γ(t - vx/(c^2)) and x' = γ(x - vt). This gives the correct solution of v(t = t') = (c^2)/v * (1 - 1/γ).
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
