Calculating Drop Time to Reach 90 km/h: Confirm/Deny!
  • Thread starter Thread starter KingNothing
    Calculation
An object dropped from rest will take approximately 2.55 seconds to reach a velocity of 90 km/h (25 m/s) under the assumption of no air resistance and constant acceleration due to gravity (9.81 m/s²). The confusion arises from misapplying kinematic equations; specifically, using distance equations instead of velocity equations leads to incorrect results. The correct formula for final velocity is V_f = V_i + a t, not V_f = 1/2 a t², which is for distance. Additionally, ensuring that units are consistent is crucial for accurate calculations. The discussion highlights the importance of correctly identifying and applying the appropriate physics formulas.
KingNothing
Can anyone confirm/deny that if an object is dropped (init. velocity=0) that it will take about 2.26 seconds to reach 90 km/h?
S=\frac{D}{T}
A=\frac{V_f-V_i}{T_f-T_i}
D=\frac{1}{2}gT^2
V_f^2=V_i^2+2a(X_f-X_i)
\overline{V}=\frac{V_f+V_i}{2}
Assuming no air resistance and an acceleration of 9.81 m/s^2, I get 2.55 seconds.
Or if the object falls for 2.26 seconds, it will have a velocity of 80 Km/hr.
Can you go through it for me? It's really confusing me as to why I keep getting what I do.
Time = Velocity/acceleration
The units I used were Seconds, m/s, m/s^2
I converted your value of 90 km/hr to m/s. Divide by 3.6 to convert km/hr to m/s. 90 km/hr = 25 m/s
I simply plugged in the values into the above formula.
T = 25 /9.81 = 2.55 seconds.
Your answer wans't really that far off. What values did you use?
Just to start off, we have to assume gravity to be 9.8 in our physics class, but I don't think that can attribute to the difference. Anyhoo, what is wrong with using:
V_f = V_i + \frac{1}{2} a t^2
If V_f=25 and \frac{1}{2}a=4.9 and V_i=0, then what should I come out with, or is this the wrong equation?
It's the wrong equation. 1/2 a t^2 is an expression of distance traveled under a constant acceleration for a given length of time.
Since V_i=0, your equation simplifies to V_f = 1/2 a t^2 which is not correct. D = 1/2 a t^2 when intial distance and velocity equal 0. Otherwise,
D = D_i+V_i t + \frac{a t^2}{2}
the units on one side of the equation have to match the units on the other side. That's a good way to check for errors in an equation.
V_f = V_i + a t
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
