How Much Does the Spring Compress When Stopping a 4000 kg Ore Car?
The discussion revolves around calculating the compression of a spring when a 4000 kg ore car rolls downhill and comes to a stop. The key equations involve potential energy, kinetic energy, and elastic potential energy, with the spring constant given as k = 400,000 N/m. Participants emphasize the importance of correctly calculating the initial potential energy of the ore car, which is derived from its mass and height. There is confusion about the relevance of the car rolling downhill, but it is clarified that this detail helps visualize the conversion of potential energy into elastic energy stored in the spring. Ultimately, the focus is on ensuring accurate calculations to determine the spring's compression.
teggenspiller
An ore car of mass 4000 kg rolls downhill on tracks from a mine. At the end of the tracks, at 10 m elevation lower is a spring with k = 400,000 N/m. How much is the spring compressed in stopping the ore car? Ignore friction.
First of all, I don't think I am visualizing this correctly. why are they telling me its rolling downhill?
F=kx
potential elatic= 1/2kx^2
tmei+Wext=tmef
i have the kei=1/2 (4000) *v^2
elastic potential at = 1/2 (400,000) (x) (by the way, we are looking for this 'x'
potential energy= either 0, OR it is mgy 400*9.8*10m
so 2000+200,000 + 39200
= 239400
so all that +wext (work of external forces) = PEf +EPEf+KEf
KEf=0, as said in the question
PEf= the same? seeing as it never went MORE downhill (thats why i am wondering why they ever told me it was originally going down hill
and EPEf= the same! i am still looking for X
so 239400 + 0Wext (?) =
Because it can't roll uphill (you have to assume it starts from rest, else you cannot do the problem.). But seriously, they want you to see that the initial potential energy when the cart starts out at rest is (finally) converted to elastic energy stored in the spring when the cart is again at rest at maximum compression of the spring.
If the car is 4000kg, this is not the correct potential energy. Find the correct potential energy. Then maybe think about what happens to the potential energy, that is, where does it end up?
