What is the force applied by the e-brake to stop the car in 3 seconds?
  • Thread starter Thread starter Shaley
    Grade 11 Phyiscs
The discussion revolves around calculating the force applied by the e-brake to stop a car after it has coasted and decelerated due to air resistance. The car, weighing 1452 kg, initially travels at 30 m/s and slows to 25 m/s over 25 seconds, resulting in an average acceleration of -0.20 m/s² and an air resistance force of -290.4 N. When the e-brake is engaged to stop the car in 3 seconds, the total acceleration required must be determined first. The combined forces acting on the car include the air resistance and the unknown force from the e-brake, which together must equal the mass times the total acceleration. The calculations will yield the necessary force exerted by the e-brake to achieve the desired stopping time.
Shaley
sue drives her 1452 kg car along a straight road at a constant velocity of 30 m/s [E]. Ger brakes suddently give out. she puts the car in neutral and let's it coast for 25 seconds. The air drag decelerates the car to a velocityof 25 m/s [E]. assume a frictionless surface.
PART C IS WHERE IM CONFUSED, BUT YOU'LL NEED TO KNOW MY ANSWERS TO THE OTHER ONES FIRST.
b)determine average acceleration while car's decelerating
m=1452 kh
v1=30 m/s [E]
v2=25 m/s [E]
t=25s
d=1/2(v1+v2)(t)
=1/2(55)(25)
=688 m
a= v2squared-v1squared/2(d)
=25squared-30squared/2(688)
= -0.20 m/ssquared
b)determine average force of air against car
F=(m)(a)
=(1452)(-.2)
=-290.4N
c)after coasting for 25s, she pulls her e-brake to slow to the car to a stop. If it takes 3s to stop the car, what is the force applied by the e-brake? Assume that the force exerted by the air remains constant and is equal to the forst determined in part (b).
In part c there are two forces providing negative acceleration. You already know one from part b. To do part c first find the total acceleration. Call it a. Then say that the known force plus the force you are looking for are mass times the acceleration that you just found.
