Why Is Calculating Golf Ball Velocity More Challenging on a Downhill Lie?
  • Thread starter Thread starter jburrus
Calculating golf ball velocity on a downhill lie is more challenging due to the differing deceleration rates on uphill and downhill slopes. For a downhill putt, the ball decelerates at 2.0 m/s², while it decelerates at 3.0 m/s² when putting uphill. This difference affects the range of initial velocities needed to stop the ball within 1.0 m of the cup. The calculations reveal that achieving the desired stopping distance is more complex for downhill lies. Ultimately, the physics of motion under varying conditions significantly impacts putting performance.
jburrus
In putting the force with which a golfer strikes ball is planned so that the ball will stop within some small distance of the cup say 1.0 m long or short in case the putt is missed. Acomplishing this from an uphill lie(that is putting downhill) is more difficult than from downhill lie. To see why assume that on a particular green the ball decelerates constantly at 2.0m/s^2 going downhill and constantly going at 3.0 m/s^2 going uphill. Suppose we have an uphill lie 7.0m from the cup. Calculate the allowable range of velocities we may impart to the ball so that it stops in the range 1.0m short to 1.0m long of the cup. Do the same for a downhill lie 7.0m from the cup. What in your results suggests that the downhill putt is more difficult?
V^2=vo^2+2a(x-xo)
I am not sure where to start
welcome to pf!
hijburrus! welcome to pf! :smile:
(try using the X2 and X2 icons just above the Reply box :wink:)
forget all about this "uphill" and "downhill" guff …
just use the given figures of 2.0 and 3.0 m/s2, and find the v0 corresponding to the given distances …
what do you get? :smile:
