How Do You Calculate the Power Output of a Motor on an Inclined Ramp?
  • Thread starter DoJang
  • Tags
    Energy
In summary, the conversation discusses a problem involving an object on a 30-degree incline ramp with a motor accelerating it at 0.22 m/s^2. The question is to find the power output of the motor, but there is not enough information to solve it. The conversation also touches on the concept of net work and potential energy in relation to an elevator moving at a constant velocity.
DoJang
:( Please help! Work,power and energy question
There is a 100kg object on a 30-degree incline ramp.
The mew of friction is 0.5.
There is a motor on top of the ramp, which accelerates the object at .22 m/s^2 by a rope.
Find the power output of the motor.
d=(vit)+(.5)(a)(t)^2
W=Fd
F=ma
P=w/t, E/s
I think I'm supposed to use Ek+Ep+TE=0,
but how am I supposed to find the power without knowing the time?
So, I've tried this method:
P=J/s
J(work)= Fxd
So I thought maybe I'll use t=1:
vi=0
vf=x
a= 0.22
d=?
t=1
d=vit+(.5)(a)(t)^2
d=(.5)(.22)(1)
d=.11m
Fnet=ma
Fa-Ff=ma
Fa-(100kg)(9.81)(cos30)(.5[mew])-(100kg)(9.81)(sin30)=(100)(.22)
Fa-424.79-490.5=22
Fa=937.29N
W=Fd
W=(937.29)(.11)
W=103.10J
P=J/s
P=103.10Watts
So here's the one approach I had,
Here is the second
Ek+Ep+TE=0
(.5)(m)(vf^2-vi^2) + mgh + (Ff)d=0
To find Vf,
Vi=0
Vf=?
a=0.22
d=x
t=1s
a=(Vf-Vi)/t
.22=Vf/1
Vf=.22 m/s
plugging it back in,
(.5)(100kg)(0.0484) + (100)(9.81)(h) + (100)(9.81)(cos30)(0.5[mew])d=0
To find d,
Vi=0
Vf=x
a=.22
d=?
t=1s
d=vit+(.5)(a)(t^2)
done above,
d=0.11m
(.5)(100kg)(0.0484) + (100)(9.81)(h) + (100)(9.81)(cos30)(0.5)(0.11) = 0
2.42 + 981h + 46.73 = 0
h=.05m
Then plug the height of .05m,
to get 98.30J/s?
Another question:
If there is an elevator moving downwards to the ground at a constant velocity,
Is the work done 0J? Is the net work between Ft and Fg the same? How should I approach this question? I know there is NOT an acceleration. W=Fd, W=mad, so no work?
Although there is a ΔEnergy?
Another question:
Momentum question,
Is the "internal work" done by an explosion equal to the combined kinetic energy of the particles? Or is it 0J? How can i visualize internal work in a bomb-like scenario?
Thank you very much.
1) Normally...
Energy = force * distance
so
Power = force * velocity
However in this case the object is accelerating so the velocity and power can't be a constant value. It will be a function of time.
I'd draw the free body diagram and calculate all the forces acting down the slope. Then multiply by the equation for the velocity V(t)=at.
2) No.
A stationary elevator is subject to 1g.
An elevator accelerating upwards at 9.8m/s/s relative to the building is subject to 2g. (One due to gravity and one due to it's motion).
An elevator descending at a constant velocity is subject to 1g
An elevator accelerating downwards at 9.8m/s/s is subject to zero g.
So although not accelerating it is being accelerated. There is a force.
The first question is missing information, so it cannot be solved. On the assumption of the one second duration, your first approach yields the average power delivered by the motor. Your second approach to this problem is muddled..you left out the work done by the rope for one thing.
Regarding the elevator problem, the term net work refers to the total work done by all forces acting on the elevator. No acceleration implies no net force and no net work. That implies that the work done by gravity and the work done by the cable have the same magnitude but of opposite signs.
CWatters said:
1) Normally...
so
2) No.
1)
E = fd,
P = fv,
So I guess I should just use 1s here as well to find Vf?
Vi=0
Vf=?
a=0.22
d=x
t=1
a=(Vf-Vi)/t
0.22=(Vf)/1
Vf=0.22m/s
To find F,
Fgx= (100kg)(9.81)(sin30)
Fgx= 490.5N
Ff= (100kg)(9.81)(cos30)(0.5[mew])
Ff= 424.79N
Fa-Ff-Fgx=ma
Fa-424.79-490.5=(100)(0.22)
Fa-915.29=22
Fa=937.29N
P=fv,
P=(937.29N)(0.22m/s)
P=206.2 Watts?
2) The question about the elevator is a very basic level physics question, doesn't touch G-forces. It's high school physics, but the one of the higher-level questions.
The first question is not missing any information, I was thinking how I can solve for the power without knowing the time. It's one of those higher-level questions for the elementary physics problems. What is your opinion on the P=fv approach I took instead of the first approach I had?
Thank you for clearing up the elevator problem. Even though there is a ΔEp, there is no Net Work done? This is hard for me to understand.
Thank you.
DoJang:
You say there is no missing information, but yet, you had to make an assumption that t = 1 second to find the power. Suppose you assumed t = 10 seconds; then you would find v = 2.2 m/s, and average power would be 10 times higher than before (1030 watts) and instantaneous power F(v) would be 2060 watts, also ten times higher. Your assumption is no better than mine; you need more info. BTW, work/time is average power; instantaneous power is F(v). The two are equal only when speed is constant , no acceleration.
Edit: I fogot to addres your question
Gravitational potential energy changes are due to the work done by gravity only, a conservative force. There is no potential energy function associated with non conservative forces like rope tensions. When gravity does work, there will be a gravitational potential energy change, regardless of whether work done by other forces results in no net work being done.
No. That would just give you the power required after t=1s at which point it is some arbitrary distance up the ramp. The velocity is changing so the power is increasing constantly. It will be consuming more power after t=2s.
As others have said, there is something missing from the problem OR you will have to give the power as a function of time.
Is the height of the ramp known? If so you could work out the velocity at the top which would give you the maximium power needed.
1. What is work and how is it measured?
Work is the measure of the amount of energy that is transferred when a force is applied over a certain distance. It is measured in joules (J) in the International System of Units (SI).
2. How is power different from work?
Power is the rate at which work is done or energy is transferred. It is measured in watts (W) in the SI system. While work is a measure of the total amount of energy transferred, power tells us how quickly the energy is being transferred.
3. What is the relationship between work and energy?
Work and energy are closely related as work is defined as the transfer of energy. This means that when work is done, energy is transferred from one form to another. The unit for work (J) is also equivalent to the unit for energy (J).
4. How is energy conserved in a system?
The law of conservation of energy states that energy cannot be created or destroyed, it can only be transferred from one form to another. This means that the total amount of energy in a closed system will remain constant over time.
5. Can you give an example of how work, power, and energy are related?
An example of how these concepts are related is a person lifting a weight. The weight being lifted requires a certain amount of work to be done, which is equal to the force applied (in this case, the weight) multiplied by the distance it is lifted. The power used to lift the weight is the amount of work done divided by the time it takes to lift it. And finally, the energy used to lift the weight is equal to the work done.
