How to Convert AND/OR Circuits to NAND/NAND Using Only NAND and NOT Gates?
  • Thread starter Thread starter mathrocks
    Logic
To convert AND/OR circuits to NAND/NAND using only NAND and NOT gates, start by analyzing the truth table and Karnaugh maps to identify the logic functions. A 3-input AND gate can be implemented using two 2-input NAND gates, where the output of the first NAND feeds into a second NAND along with the third input. For a 4-input AND gate, use three 2-input NAND gates to achieve the same result. The key is to apply De Morgan's theorem to transform the logic expressions appropriately. Visualizing the circuit can simplify the conversion process significantly.
mathrocks
I have to make a circuit using only NAND and NOT gates to drive a 7 segment LED. My problem is that after I make the truth table and draw the karnaugh maps I of course end up with a AND/OR circuit...how exactly can I convert the AND/OR to a NAND/NAND. Also, how can I break up the 3 and 4 input AND gates to 2 input NAND gates.
I really need help with this, I've been racking my brain trying to figure this out.
Thanks alot!
Ok, think of this. Take a simple NAND truth table.
NOT the output. You get ________
NOT the two inputs. You get ________
A 3 input AND can be 2 inputs into an AND with output fed into another AND along with the third input. A four input, use three ANDs. Etc.
If you draw it out I believe its that simple.
Cliff
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
