Basic Mechanical Methods: Recommendations for Engineers
  • Thread starter Thread starter Karol
    Book
For learning basic mechanical methods, particularly in calculating forces on riveted joints and other connections like welds and bolts, "Shigley's Mechanical Engineering Design" is highly recommended. Additional resources include "Engineering Materials 1 & 2" by Ashby & Jones for material properties and "Engineering Mechanics: Statics" for foundational principles. "Norton's Machine Design: An Integrated Approach" is also suggested for a comprehensive understanding. These texts provide essential knowledge for mechanical engineers focusing on force calculation principles. Overall, these resources will enhance understanding of mechanical design fundamentals.
Karol
I'm interested in learning basic mechanical methods.
For example, calculation of forces on rivetted joints subjected to moment, in which I have to find the joint's center of rotation etc. I'm not interested in in-depth design of the rivet, but merely the force finding principles.
And other subjectes like those: Welds, Bolts, etc.
Can you recommend a high level, general, book?
I'm a mechanical engineer.
Thanks.
shigley mechanical design is a great book where you can find about welding , bolts and bearings etc...
the name of the books is :Shigley's Mechanical Engineering Design (Mcgraw-Hill Series in Mechanical Engineering)
I'd recommend you get a book on Materials and on Static forces. Engineering Materials 1 & 2 by Ashby & Jones might be a good start as well as Engineering Mechanics: Statics.
Norton's Machine Design: An Integrated Approach is really good.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
