How Do You Calculate Fuel Consumption Over Time in a Mathematical Model?
  • Thread starter Thread starter steve 99
steve 99
I have this questions an answer to it would be great.
.Q.1 At t minutes after an engine starts, the rate of fuel consumption is Rkg per minute. it is given by R=10+ 10/2t+1.
a) Sketch R as a function of t
b) find the rate of consumption after 7 mins
c) find the limiting value of R as t becomes very large
d) calculate the total consumption in the 1st 7 mins
not sure how to do it
Thank You
I can do part 2
Is that rate supposed to be R = 10+ [10/(2t+1)] ? I think it would be for question (c) to have a sensible answer. The question is asking you what the limit of R is as t goes to infinity.
As for (d), you have a function giving you the *rate* of consumption with time. If you want to know how *much* fuel has been used in the time interval 0 <= t <= 7 minutes, what operation must you perform on the function R(t)?
so wat is the function is that R(t)= 10+(10/2t+1)
Yes, that is the fuel consumption rate function.
so i no the value will not go >10 or equal to 10 but I am not sure how to calculate that
i no it wll approach but neva touch 10 if you graphed but as i said not sure on the calculations
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
