What Explains the Lack of Current in a PN Junction at Equilibrium?
In summary, a PN junction with phosphorous doping on the N side and Boron doping on the P side creates a depletion region with an electric field pointing from N to P. In equilibrium, the depletion region acts as an insulator and the drift and diffusion currents cancel, resulting in zero net current. This is due to the movement of electrons and holes caused by the electric field and random thermal motions.
unified
40
TL;DR Summary
I am considering a PN junction at equilibrium, and have a couple of questions.
Consider a PN junction doped with say phosphorous on the N side, and Boron on the P side. Initially, there is an opportunity for the electrons just below the N conduction band to drop to the lower available energy states just above the P valence band. This leaves the N side positively charged and the P side negatively charged, forming a depletion region. This means that there will be an electric field pointing in the direction from N to P. Eventually, there will be an equilibrium that is reached, in which case there is no current in the depletion region.
I do not know which of the following explains why there is no current in the depletion region under equilibrium.
1. The electric field causes electrons from the negatively charged P side to flow back to the N type, and in equilibrium this cancels the flow of electrons from N to P. Also, the electric field causes holes to flow from N to P, and this cancels any holes flowing from P to N. The result of these processes is zero net current.
2. There is no current flowing either from N to P or P to N in equilibrium. In equilibrium, the depletion region is essentially an insulator, and while we have an electric field present in the region, the charge is not free to flow.
(2) is clearly wrong. The holes and electrons are free to move. (1) is closer, but isn't very clearly stated. Exactly which currents cancel? Try drawing a sketch to show the various currents.
Likes unified
phyzguy,
A sketch would include four currents, two from the field (electrons move against the field, holes with the field) and two due to random thermal motions (electrons from P to N, holes from N to P). In equilibrium these effects cancel.
unified said:
phyzguy,
Exactly. This is much more clearly stated than your original (1). In semiconductor nomenclature, the currents driven by the electric field are typically called "drift currents" and the currents due to random thermal motions are typically called "diffusion currents". The drift currents obey Ohm's law (J = σE), and the diffusion currents are driven by concentration gradients and obey Fick's law (J=-D∇n).
Likes unified, berkeman and Baluncore
Related to What Explains the Lack of Current in a PN Junction at Equilibrium?
1. What is a PN junction at equilibrium?
A PN junction at equilibrium is a type of semiconductor junction that occurs when a P-type semiconductor and an N-type semiconductor are brought into contact with each other. This creates a depletion region at the junction, where the free electrons from the N-type material combine with the holes from the P-type material, resulting in a net charge of zero.
2. How does a PN junction at equilibrium behave?
A PN junction at equilibrium behaves like a diode, allowing current to flow in one direction but not the other. This is due to the built-in potential created by the depletion region, which acts as a barrier for electrons trying to flow from the N-type material to the P-type material.
3. What factors affect the width of the depletion region in a PN junction at equilibrium?
The width of the depletion region in a PN junction at equilibrium is affected by the doping levels of the P and N-type materials, as well as the applied voltage across the junction. Higher doping levels will result in a narrower depletion region, while a reverse bias voltage will widen the depletion region.
4. How does temperature affect a PN junction at equilibrium?
Temperature can affect a PN junction at equilibrium in two ways. Firstly, an increase in temperature can cause the depletion region to shrink due to the increased thermal energy of the electrons and holes. Secondly, temperature can also affect the mobility of charge carriers, which can affect the overall behavior of the junction.
5. What is the significance of a PN junction at equilibrium in electronic devices?
PN junctions at equilibrium are essential components in many electronic devices, such as diodes, transistors, and solar cells. They allow for the controlled flow of current in one direction, making them useful for rectifying AC signals, amplifying signals, and converting light into electricity. They also have a wide range of applications in integrated circuits and microelectronics.
  • Electrical Engineering
