Pogo Stick and Spring Constants
  • Thread starter Thread starter techninja
    Constants Spring
The discussion focuses on the physics of a pogo stick, specifically the energy transformations involving a spring with a spring constant of 40000 N/m. The total mechanical energy of the system was calculated to be 411.78 J, with the maximum upward position determined to be 1.62 m. The speed of the child at the equilibrium position (x = 0) was found to be 5.63 m/s. Participants discussed how to find the position where kinetic energy is maximized, emphasizing that this occurs before reaching x = 0, where potential energy is minimized. The conversation highlighted the importance of understanding forces acting on the system, including gravitational force and the force exerted by the spring.
techninja
http://img178.imageshack.us/img178/75/43802nv4.jpg
A child's pogo stick (see figure) stores energy in a spring of spring constant k = 40000 N/m. At position A, x1 = -0.150 m, the spring compression is a maximum and the child is momentarily at rest. At position B, the spring is relaxed and the child is moving upward. At position C, the child is again momentarily at rest at the top of the jump. Assuming that the combined mass of child and pogo stick is 26.0 kg, answer the following:
(a) Calculate the total energy of the system if both potential energies are zero at x = 0
I did this through:
<br /> ME_i = U_s + U_g = \frac{1}{2}kx^2+mgh = 411.78 J<br />
(b) Determine x2
I did this through:
<br /> ME_i = ME_f = U_g<br /> ME_i = mgh
<br /> x_2 = \frac{ME_i}{mg} = 1.62 m<br />
(c) Calculate the speed of the child at x = 0
I did this through:
<br /> ME_i = \frac{1}{2}mv^2<br /> v = \sqrt{\frac{2ME_i}{m}} = 5.63 m/s<br />
(d) Determine the value of x for which the kinetic energy of the system is a maximum.
Hint: The kinetic energy (and velocity) is a maximum when the acceleration is zero at that point.
This one, I tried very hard... but I can't do it.
I get:
<br /> v = \sqrt{\frac{2(1378-mgh)}{m}}<br /> a = \frac{1}{m\sqrt{\frac{2h}{m}}}<br />
Tex hates me. It should look something like v = sqrt([2(1378-mgh)]/m), so a = 1/(m*sqrt(2h/m))
Which doesn't seem to work out nicely.
(e) Obtain the child's maximum upward speed
I think I could do this with information from D, but ... I'm not sure.
Any help is muchly appreciated!
This is easier than you think. First realize that as soon as the system passes x = 0, the speed can only decrease. So the max speed must occur before that point. Use your expression for total ME as a function of position and solve for the value of x that maximizes KE. (For KE to be max, PE must be min.)
For an even easier solution, use your own idea that the acceleration must be zero: For the acceleration to be zero, the net force must be zero. Where is that point?
I'm not sure what you mean. If I try to find position, I end up with:
<br /> KE = ME_i - mgh
Where ME_i is a constant, as are m and g. Thus, I get a linear equation.
For the latter comment, I'm not sure how the free-body diagram should then be drawn as. There's force of gravity going downwards, but isn't kinetic energy upwards in units of joules? How can I change that?
Don't forget spring PE, which is also a function of position.
(1) KE is not a force. And energy is a scalar, not a vector--it has no direction. (You probably mean that the velocity is upwards, but that's also irrelevant.)
(2) There are two forces acting on the system. Gravity is one. What's the other?
Thank you verily much! It suddenly makes sense! (I was wondering why the spring constant was perfectly related to part d)
I still don't understand the second approach, however. Is it possible to find the other force? (Which I assume is just... force imparted upwards?)
Of course it is. What is exerting the upward force on the system? (Hint: It's the same thing you missed with the first approach!)
Note: The two approaches are just different ways of doing the same thing.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
