Point mass gravitational problem
To find the point on the x-axis where the gravitational field g equals zero due to two point masses, the equation g1 + g2 = 0 is established, leading to a quadratic equation. The derived equation x^2 - 4x + 12 = 0 has no real solutions, indicating that there is no point on the x-axis where the gravitational fields from the two masses cancel each other out. The discussion raises questions about the meaning of g=0 in terms of gravitational fields and whether gravitational fields are vector fields. Clarification is sought on how to approach the problem correctly. Understanding the vector nature of gravitational fields is essential for solving such problems.
nns91
1. A point mass m1= 2kg is at the origin and a second point mass m2=4kg is on the x-axis at x=6m. Find the point on the x-axis for which g=0
g= -Gm/r^2
So g=0 means that g1+g2=0. I set up that 2(r2)^2= -4(r1)^2 and made r2=x-6 and r1=x.
Thus, I have a quadratic equation as x^2 -4x+12=0 which has no solution. I am wrong on this question. How should I fix this ??
What would g=0 mean?
gravitational field.
Is the gravitational field a vector field?
