Point on plane closest to point in R3
  • Thread starter Thread starter TsAmE
    Plane Point
TsAmE
Let P1 be the plane passing through the point A(5,-6,7) parallel to the xy-plane. Write down the coordinates of the point D on P1 which is closest to C(1,3,4).
None.
I am not sure how to attempt this problem. I tried sketching a diagram (attached), but didnt know what else to do.
Have you tried deriving the equation of the plane P1 ?
The equation of a plane is given as follows
a(x-x_{0}) + b(y-y_{0}) +c(z-z_{0}) =0
(a,b,c) is a normal vector to the plane.
It turns out that the distance between a point and a plane is shortest when the point is orthogonal to the plane.
It's a trick question. You know that the shortest distance from a point to a plane is in the normal direction to that plane. what is the normal to the plane they defined?
Thanks, I figured it out D(1,3,7) :)
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
