Poisson probability distribution
The discussion revolves around a particle detector that identifies type A particles through a Poisson process with a rate of 0.5 per day. The probability of detecting three or more type A particles in one day is calculated as 0.01439, while the inter-detection times for these particles follow an exponential distribution with a mean of 1/λ. There is some confusion regarding the calculation for the inter-detection time, which is clarified as the time between consecutive detections. Additionally, the probability of detecting at least one type A particle given that at least one type B particle is detected is calculated to be 0.2425. The thread emphasizes the importance of understanding the foundational concepts of probability to solve these problems effectively.
Maybe_Memorie
A particle detector is set up to detect type A particles. These are detected as a poisson process with parameter lamda = 0.5 per day.
(i) What is the probability that 3 or more will be detected in anyone day?
(ii) What is the distribution of inter-detection times for these particles?
(iii) What is the probability that the inter-detection time for two consecutive particles will be less than 3 days?
(iv) The detector also detects type B particles. These occur with rate lamda = 0.5 when no type A are detected, and rate lamda = 1 when 1 or more type A are detected. If on anyone day one or more type B are detected, what is the probability one or more type A are also detected?
(i) was easy. I got 0.01439
For (ii) I have absolutely no idea what to do.
For (iv), I used P(at least 1 A | at least 1 B) = (at least 1 A and 1 B)/P(at least 1 B)
I ended up getting 0.2425.
Is this correct?
Is this correct?
For part (ii): this is standard probability theory. Do you have a probability textbook or lecture notes? I would be surprised if the answer cannot be found therein. However, if that (i.e., a relevant text or notes) does not cover your situation, you can give us more information about your situation. The real problem is that (ii) is easy, but needs some elementary but lengthy preliminary work (or else just needs cookbook quoting with no understanding attached). Of course, once you have (ii), getting (iii) is easy.
RGV
RGV
I'm using the book by Sheldon M. Ross
The problem is I don;t know what (ii) is actually asking.
It is asking for the distribution of inter-arrival times in a Poisson process.
RGV
RGV
I still have no idea how to calculate this.
Ross has written several Probability textbooks. You don't say which one you are using, but that matters not at all: they are all excellent and all have everything you need. Here is a hint: read the book.
The "inter-detection time" is the time between two consecutive clicks of the counter.
It's "Introduction to Probability and Statistics for Engineers and Scientists".
And actually, I have read the book.
I understand this. It's the time between the "n"th particle and the "n+1"th particle.
But I don't know how to find this distribution.
Hi Maybe_Memorie! :smile:
I see this thread is still hanging.
Do you have the answer by now?
Hi! :smile:
The inter-detection time is given by the exponential distribution with mean 1/lamda, yes?
Yes! :cool:
Thanks! :smile:
Do you have any other hanging threads?
