Polarization of Waves: Solutions & Explanations
Billy246
1. Info
Basically, I'm having trouble with this question and it's constituent parts.
http://img181.imageshack.us/img181/6986/question8tn5.jpg
No equations for first two parts, it's the visualising that I'm finding tricky.
Part 3 will require some sort of angular velocity equation, yet I'm still unsure.
Question part i) Answered (c) horizontally north-south. This seems the logical answer as it is perpendicular to the wave motion.
Question part ii) Shot in the dark would lead me to answer a.
Question part iii) Got lost in the calculation and cannot be sure of calculated answer. I guessed the answer to be answer c - 58 x 10^9
Any help would be greatly appreciated if any is given. Thank you.
Kind Regards,
Billy
(i): When an EM-wave is said to be polarized, the convention is that you are talking about the polarization of the E-field. So in this question, we are told that a plane EM-wave is moving towards right, and the plane of polarization is vertical. So I would say (a).
(ii): The B-field always oscillates in such a way to be orthogonal to the E-field. From (i) I would say (c).
(iii): From the equation for E you see that the magnitude of the wave number k is 260 m^{-1}. Since the wave is traveling in air, we will say the velocity is c. Then we have:
<br /> k=\frac{\omega}{c} \Leftrightarrow \omega = kc.<br />
Thus we get (d).
Have a happy New Year :smile:
Thus we get (d).
Thank You Niles,
Much appreciated. Hope the New year treats you well!
Regards,
Billy
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
