Determine Polyatomic Charge: Sulfate (SO4)
  • Thread starter Thread starter yyttr2
    Charge
Determining the charge of polyatomic ions like sulfate from their names is not straightforward, as it often requires knowledge of the central atom's typical ionic charge. The charge of the central atom can sometimes indicate the charge of the polyatomic ion, particularly for elements in periods 3 or greater and groups 15 through 17. The suffix "-ate" denotes the higher charge of oxyanions, while the absence of the prefix "per-" suggests all oxygen atoms have a -2 charge. For example, sulfur typically has an oxidation state of +6 in its oxyacids. Understanding these relationships is essential for accurately writing chemical formulas.
yyttr2
In writing a formula from the name of an element I can safely say I know how to figure out the number of oxygen it will have.
But take:
Sulfate: So^{-2}_{4}
How do you determine the charge of it with just the name?
Chemistry news on Phys.org
From the name? You don't. However, I have had some success with looking at the charge the central
atom would hold if it were an ion, which is often (but not always; see carbonate and nitrate for counterexamples) the same as the charge of the polyatomic ion, however many oxygens there are. For example, all of the oxyacids of chlorine have the same charge as a chlorine ion, all of the oxyacids of sulfur and phosphorus have the same charge as sulfur and phosphorus ions, and so forth.
This idea that I use only seems to work in periods 3 or greater, and in groups 15 through 17 (or 5A through 7A).
The suffix -ate is given to the higher of the oxyanions in the series. Without the prefix 'per-', assume the oxygens are all of -2 charge. Assume the the sulfur is in its normal oxidation state of +6 (sulfur has oxidation states of -2, +4 and +6) since you memorized(!) the charges of all of the oxyanions, of course!
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
