Position as a function of position?
  • Thread starter Thread starter asap9993
    Function Position
7 replies · 7K views
asap9993
Here's the problem:
Suppose the acceleration of a particle is a function of x, where a(x) = (1.8 s^-2)x.
a) If the velocity is zero when x = 1.0 m, what is the speed when x = 2.9 m?
b) How long does it take the particle to travel from x = 1.0 m to x = 2.9 m?
a = dv/dt
v = dx/dt
I managed to figure out how to do part a.
a = dv/dt
(dt/dx)a = (dv/dt)(dt/dx)
Since v = dx/dt, the above equation becomes
a(1/v) = dv/dx which becomes
a dx = v dv.
Integrating both sides gives you
v^2 = (1.8s^-2)(x^2) + C (s is seconds)
Since v = 0 when x = 1.0 meters, C = -(1.8s^-2)(m^2) (m is meters)
So the final function is v^2 = (1.8s^-2)(x^2) - (1.8s^-2)(m^2)
Plugging in x = 2.9 m, gives 3.65 m/s which is the correct answer.
I can't figure out part b. I tried using the same approach as in part a to find a "time function" :
v = dx/dt so
dt = (1/v) dx
However. when I integrate this, it doesn't give me the correct answer which is 1.29 s.
Can anyone please help me?
a dx = v dv.
Check the above integration.
You have obtained
v^2/2 = 1.8(s^2)(x - 1)
v = sqrt[2*1.8(s^2)(x - 1)]
dx/dt = sqrt[3.6(s^2)(x - 1)]
dt = dx/sqrt[3.6(s^2)(x - 1)]
Now you can find the integration.
To rl.bhat,
Shouldn't it be (x^2 - 1) instead of (x-1)? And I did the integration. It gives a natural log equation that doesn't give me the right answer
The integration adx = ax and integration of vdv = v^2/2. Now proceed.
asap9993 said:
To rl.bhat,
To asap9993
Yes, x2‒1
Also, It's v2 like you had, not v2/2.
Altering rl.bhat's solution with those changes gives:
√[1.8(s‒2)]dt = dx/√[(x2 - 1)]
Integrate to get t ≈ 1.287 s
SammyS said:
To asap9993
Yes, x2‒1
QUOTE]
Integration of xn = x(n+1)/(n+1)
In asap9993's equation, a dx = v dv, the quantity, a, is not a constant. a = kx, where k=1.8s‒1
So, upon integrating, asap9993 dropped the 2 in the denominator on both sides.
kx·dx = v·dv → kx2/2 + C/2 = v2/2
→ (1.8s‒1)x2 + C = v2 , which is what asap9993 had.
