Position of the front of an asteroid using special relativity
The discussion centers on calculating the position of the front of an asteroid using special relativity principles, specifically the Lorentz transformation. The asteroid, with a rest length of 300 m (1 µls), moves at a speed of v = √(3/2)c. The calculations reveal that the length contraction results in a length of 0.5 µls in the moving frame F, with the front end located at x = 4.5 µls in F and x' = 1 µls in F'. The final position of the front end in F, corresponding to the rest frame, is determined to be x = 6 µls.
  • Understanding of special relativity concepts, including length contraction and reference frames.
  • Proficiency in using the Lorentz transformation equations: x' = γ(x - vt) and x = γ(x' + vt').
  • Familiarity with the concept of the Lorentz factor (γ) and its calculation.
  • Ability to interpret and create space-time diagrams for relativistic scenarios.
  • Study the implications of length contraction in different inertial frames using examples from special relativity.
  • Learn how to derive and apply the Lorentz transformation in various scenarios involving relative motion.
  • Explore the concept of simultaneity in special relativity and how it affects observations in different frames.
  • Investigate the effects of relativistic speeds on time dilation and its mathematical representation.
Students and educators in physics, particularly those focusing on special relativity, as well as researchers interested in relativistic effects in astrophysics and high-speed particle physics.
TheGreatCabbage
I'm stuck on part (d) but I've included the previous subquestions in case they're useful.
The length of an asteroid is exactly 300 m = 1 µls (micro light-second) when at rest. Draw a carefully labelled space-time diagram to illustrate the following:
(a) Depict the rest frame F′ of the asteroid, when it is moving along the x-axis at speed ##v = \sqrt{3/2}c## in the diagram reference frame F. The two reference frames can be taken in standard configuration
(b) In the diagram of part (a), depict the asteroid in both reference frames, when the rear end of the asteroid lies at the origin. Find the length of the asteroid in F.
(c) For a given position of the back end, the front ends of the asteroid in F and F′ are different events. Find, in F, the spatial locations of these events (i.e. of the front ends of the asteroid in both frames) when the rear end of the asteroid lies at the origin (i.e. when t = t′ = 0).
(d) Depict the asteroid in both reference frames at a later time, when the rear end lies at x = 4 µls in frame F. Find the locations in F of the front ends of the asteroid in both frames. What is the location in F′ of the front end at this time?
Lorentz transformation: ##x'=\gamma (x-vt)## and ##x=\gamma (x'+vt')##
I'm confused about the wording of the question: find the location of the front end of the asteroid in both frames in F, and finally in F'? I don't quite get it.
Anyway, ##\gamma=2## so I think the length in F should be (where L is the length at rest) ##l=\frac{L}{\gamma} = 0.5\mu ls##. This implies that the position of the front end in F is at ##x=4.5\mu ls##. I'm not sure how to do anything else, since I don't know the time in either frame.
Any help would be greatly appreciated!
The problem statement gives you the distance traveled in F and the speed in F.
(Correction for original post: the speed is supposed to be ##\frac{\sqrt{3}}{2}c##, which then gives ##\gamma=2##.)
Thanks, I can't believe how long I spent without noticing that. So, the time in ##F## is: $$t=\frac{D}{v}=\frac{8}{3}\sqrt{3}\mu s$$ Therefore the time in ##F'## is: $$t'=\frac{t}{\gamma}=\frac{4}{3}\sqrt{3}\mu s$$
The front of the asteroid in ##F'## is at ##x'=1\mu ls## because that's the rest frame of the asteroid, and the front of the asteroid in ##F## is at ##x_1=4.5\mu ls## because the length in ##F## is ##0.5\mu ls##. Lastly, the position in ##F## corresponding to the front end of the asteroid in ##F'## is: $$x_2=\gamma (x'+vt')=6 \mu ls$$
I hope I haven't made any massive mistakes? Thanks very much for your help :-)
  • · Replies 40 ·
  • · Replies 36 ·
