How to Find the Maximum Area of a Rectangle on a Parabola
  • Thread starter Thread starter Jude075
    Area Maximum
Jude075
A rectangle has its base on the x-axis and its vertices on the positive portion of the parabola
$$ y=2-3x^2 $$
What is the maximum possible area of this rectangle?
A. (8/27)*181/2 B.(2/9)*181/2 C. (4/15)*301/2 D.(2/15)*301/2 E.(1/3)*121/2
The definite integral (or the area underneath the curve) from 2/3 to-2/3, which are the x-intercepts, is 56/27 .Since the rectangle is inside the parabola, I just need to find the number that is the closest. It is choice C, but the answer turns out to be A.
The intercepts of y = 2 - 3x^2 are NOT 2/3 and -2/3. Maybe this is your problem?
If you draw a rectangle with base length 2x with the conditions you gave, the area of the rectangle is 4x - 6x^3. This function has derivative 4 - 18x^2, which becomes zero at...
Can you continue the solution?
If the upper corners of the rectangle are at (x, y) and (-x, y) then the area of the rectangle is 2xy.
Since y= 2- 3x^2, that area is 2x(2- 3x^2)= 4x- 6x^3.
So how do you guys use that expression to find its area? Do I derive it or integrate it?
You now have a function
A=4x-6x^3
Where A stands for area. For different values of x, you'll get a different value of A, correct? You want to find the maximum area the rectangle can be, hence, you want to find the maximum of A, so how do you do that?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
