Potential difference and ohms law
In a circuit with a 3 ohm and a 1.5 ohm resistor in parallel, connected in series to a 4 ohm resistor and a 10 V emf device, the equivalent resistance of the parallel resistors is calculated to be 1 ohm. This results in a total resistance of 5 ohms when combined with the 4 ohm resistor. Using Ohm's Law, the total current is determined to be 2 amps. The voltage drop across the 4 ohm resistor is 8 volts, leaving 2 volts for the parallel resistors. Since the voltage across both parallel resistors is the same, the potential difference across the 3 ohm resistor is 2 volts.
nautica
A 3Ohm and a 1.5 ohm resistor are wired in paralles and the combination is wired in series to a 4 ohm resistor and a 10 V emf device. The potential difference on across the 3 ohm resistor is?
I reduced the 2 in parrallel to 1.875 ohms and then addes the 4 ohm, which gave me a total resistance of 5.875 ohms. Then measured the current using ohms law, which gave me 1.7 amps. Then multiplied that times the 3 ohms to get 5.1 V.
But that is not one of the answer choices, where did I go wrong.
these are the choices: 2V,6V,8V,10V,12V
Thanks
Nautica
Wouldn't the equivalent resistance be 1? making the total resistance 5 ohms? Then you'd have a (10/5)*1 volt drop across the 2 resistors in parallel and a (10/5)*4 volt drop across the 4 ohm resistor.
Look at the resistors in parallel again:
R_{eq} = \left(\frac 1 3 + \frac 1 {1.5} \right)^{-1} = \left(\frac{1+2}{3}\right)^{-1} = 1
nice, maybe I need to go back to 3rd grade math.
I am still not coming up with the answer.
If the total resistance is the 1 ohm, which i reduced, plus the 4 ohm in series. That gives me a total resistance of 5 ohms. Then I plug that into ohms law, which is V=IR and it gives me a total current of 2 amps.
To find the potential difference on the 3 ohm, I would have to cut the current in half, which is 1 and then use ohms law, which is V=IR so 1 x 3, which gives me 3, but that is wrong.
Nautica
I'm getting the answer as being 2V
Resistance of parallel things
R = (3^-^1 + 1.5^-^1)^-^1
R = 1 \Omega
resistance total
R = 1 + 4
R = 5\Omega
total current:
I = \frac{V}{R}
I = \frac{10}{5}
I = 2A
voltage drop over the 4\Omega resistor:
V = IR
V = (2)(4)
V = 8V
voltage remaining:
V = 10 - 8
V = 2V
So how is that split between the remaining 3 and 1.5 ohm on the parrallel
It isn't. When dealing with a parallel, the voltage is the same in each path. That's why hooking lightbulbs in parallel makes power consumption much higher than hooking them in series.
