What Differentiates Work Done by a Spring vs Work Required to Stretch It?
The discussion clarifies the distinction between the work required to stretch a spring and the work done by the spring when released. When a spring is stretched from position x1 to x2, positive work is done on the spring, which converts to potential energy. Conversely, as the spring is released, it performs negative work on the surrounding environment. The confusion arises around the signs of work and energy changes, with the relationship ΔU = -W emphasizing that the work done by the spring is opposite to the work done on it. Ultimately, understanding these concepts is crucial for grasping spring mechanics and energy transformations.
daivinhtran
What is the difference between "the work required to stretch a spring" and "the work done by a spring"?
Fdx = dW
F (from the spring)= -kx
so, F (from me) = kx
I have tried and I found out the work required to stretch a spring x1 to x2 is(1/2)k(x2^2 - x1^1)
and "the work don't by a spring" when it's released from x1 to x2 is the same thing but in opposite sign
Am I right?
Am I right?
Yes, except for the word "released". When you stretch the spring from x1 to x2, you do positive work on the spring--that's the work required to stretch the spring, which becomes spring potential energy. At the same time, as the spring is being stretched it is doing negative work on you.
Thank you
I meant "released" as in another situation.
If the spring is already compressed and then is released from x1 to x2
the work done by the spring is -(1/2)k(x2^2 - x1^1) (because the force is pointing in opposite direction.
I'm still confused when you say "that's the work required to stretch the spring, which becomes spring potential energy." By the definition the ΔU= - W(done by the spring) , not by me though
Can you explain me please?
daivinhtran said:
Thank you
If it's compressed and being released, then x1 > x2. Right?
This is confusing, since I don't know if x1 > x2.
If W is the work done by the spring, then -W is the work done by you. If you stretch the spring, the spring does negative work. (Since force and displacement are opposite.) Thus you do positive work and ΔU is positive.
I finally got it...
