Potential Energy Car Downhill Question
The discussion revolves around calculating the speed of a car at the bottom of a hill after coasting down from a height of 36 meters. The potential energy (PE) at the top is calculated as 388,476 J, and the kinetic energy (KE) at the top is based on its initial speed of 16 m/s. The total mechanical energy is conserved, meaning the sum of initial PE and KE equals the KE at the bottom. The correct approach involves combining the energies under a single square root to find the final speed, rather than separating them. The final speed calculation should yield a value greater than the initial speed due to the conversion of potential energy into kinetic energy.
lando45
I was set this question and have no clue how to solve it...
A 1100 kg car racing up a mountain road runs out of gas at a height of 36 m while traveling at 16 m/s. Cleverly, the driver shifts into neutral and coasts onward. Not having any brakes, at what speed will the car reach the bottom of the hill?
I found mgh of the car as 1100 x 9.81 x 36 and then equated this to 1/2mv2 to try and find velocity and I got 26.5m/s but this is wrong...any help? Thanks
what about the kenetic energy of the car when it is at 36m?
PE of car at 36m = mgh = 1100 x 9.81 x 36 = 388476
PE of car at 0m = mgh = 0
KE of car at 36m = 1/2mv2 = 1/2 x 1100 x v2 = 550v2
KE of car at 0m = 1/2mv2 = 550v2
Now where can I go from here?
what about Energie(s) intial = Energie(s) final
OK here's what I got for initial energies = final energies...(v = at the peak of the mountain and V = at the bottom)
388476 + 550v2 = 0 + 550V2
623.27 + 550v = 550V
1.133 + v = V
V = 1.133 + 16 = 17.133
But this is wrong...
The total mechanical energy of the car is the sum of its kinetic energy and its potential energy, both of which you know for the height of 36 m.
By the time the car reaches the ground, all of its mechanical energy (which is conserved) is kinetic energy - or, in other words, all of its original potential energy has been converted to kinetic energy (in addition to its original kinetic energy).
1.133 + v = V
What exactly did you do here? It looks like you took square roots of some of the numbers separately, which really isn't allowed. The first equation is correct and you can solve for V simply by diving both sides with 550kg and then taking the square root. You should note however, that all the numbers must be within the same square root, you can't take the root from each one separately.
