What Is the Potential Energy at x = 2.0 m for a Particle Under a Variable Force?
In summary: In Newtonian mechanics, at least). I was about to criticize HallsofIvy for not answering the question, but then I realized that the was the perfect answer for you.In summary, the potential energy for a particle moving along the x-axis under the influence of a variable force F(x) = 6.8x^2 + 3.0x, measured in Newtons and meters, at x = 2.0 m is found by taking the anti-derivative of the force function, which is 6.8x^3/3 + 3.0x^2/2, and evaluating it at x = 2.0 m. This gives a potential energy of
Moxin
24
A particle moves along the x-axis under the influence of a variable force F(x) = 6.8x^2 + 3.0x where the force is measured in Newtons and the distance in meters. What is the potential energy associated with this force at x = 2.0 m? Assume that U(x) = 0 J at x = 0 m.
The formula I was trying to work with (from the book) is
dU = -F*ds where U is the potential energy and s is the displacement..
Anyways,.. I went on ahead a plugged 2 into the equation, and I got 33.2, the Force.. then I multiplied the negative of that by 2.. the displacement, but apparently the answer is wrong. So I'm guessin the derivative of displacement is indeed different than the regular displacement..so I guess my question here is, how do i find the derivative of displacement? Sorry I'm jus now starting calculus this year and am not completely familiar with the concept yet..
Exactly. One of the basic rules of physics is: whatever mathematics you need for this semester's physics course, you will study NEXT semester!
dU= f(s)ds is the correct generalization of "Work= force times distance" which is only true when force is a constant.
To go from "dU= f(s)ds" to "U= ...", you need to find the anti-derivative or integral. In this case you have:F(x)= 6.8 x so you need to find the integral of 6.8 x dx from x=0 to x= 2.
Have you yet learned the derivative rule (xn)'= n xn-1? or it's anti-derivative twin int xndx= (1/(n+1))xn+1?
If not, you may just need to content yourself with looking at a table of integrals in your calculus textbook (they are often on the inside of the covers).
Another point just occurred to me: as long as the "rate of change" is itself constant and the force function is linear (as here), you can use the "average force". What is the force when x= 0? What is the force when x= 2? What is the average of those two numbers? Use that as the force and multiply by 2.
Of course, your teacher might just ask you to justify that!
Well, I tried this method since I still didn't really understand how to get the derivative of x, and ended up getting it wrong again, then I realized it's because the force function isn't linear.. you left off half the eq'n lol its parabolic (F(x) = 6.8x^2 + 3.0x) ..So I guess now I have to try to understand your first suggestion.
And Yeh, I just learned the derivative rule the other day, I know how to apply it when given an eq'n (i.e. F(x)).. but not just with a lone variable (x).. wouldn't it just be one everytime? So that dU = F(s) ? So the eq'n would be simply dU = F(s) ?
You're right. I completely misread the force function. You have
F(x) = 6.8x^2 + 3.0x so the potential energy is the anti-derivative of 6.8x^2 + 3.0x- the function whose derivative is 6.8x^2+ 3.0x.
Okay, you say you have learned the power rule: the derivative of
x^n is n x^(n-1). What we need to do here is reverse that.
Notice that the derivative reduces the power by 1. If the derivative is x^2, then we must have had x^3 to start with. But x^3 alone won't work: it's derivative is 3x^2. We need to get rid of that "3". Okay, multiply by (1/3). What is the derivative of
(1/3)x^3? To get the anti-derivative of 6.8x^2, just multiply that (1/3)x^3 by 6.8.
Similarly, if the derivative is x, then we must have had x^2 to start with. But the derivative of x^2 is 2x. We need (1/2)x^2 to wind up with (1/2)(2x)= x. To get the anti-derivative of 3.0x, just multiply by 3: 1.5x^2 has derivative what?
Of course, since the derivative of f + g is the derivative of f plus the derivative of g, to find the function whose derivative is
6.8 x^2+ 3.0x, just add the two functions above.
By the way, the derivative of any constant is 0 (a constant function doesn't increase or decrease) so we could add any constant to what we got before and not change its derivative. That's the reason potential energy is always relative!
Related to What Is the Potential Energy at x = 2.0 m for a Particle Under a Variable Force?
1. What is potential energy?
Potential energy is the energy that an object possesses due to its position or state. It is stored energy that has the potential to be converted into other forms of energy, such as kinetic energy.
2. What is a potential energy problem?
A potential energy problem is a physics problem that involves calculating the potential energy of an object or system in a given scenario. It often requires the use of formulas and equations to determine the potential energy of the object.
3. How is potential energy calculated?
The formula for calculating potential energy is PE = mgh, where m is the mass of the object, g is the acceleration due to gravity, and h is the height of the object above a reference point. This formula applies to objects in a gravitational field, such as on Earth.
4. What are some examples of potential energy?
Some examples of potential energy include a stretched rubber band, a compressed spring, a ball at the top of a hill, and water held behind a dam. These objects all possess potential energy due to their position or state.
5. How does potential energy relate to kinetic energy?
Potential energy and kinetic energy are two forms of energy that are interrelated. When potential energy is converted into kinetic energy, the object's position or state changes. For example, when a ball at the top of a hill starts rolling down, its potential energy is converted into kinetic energy.
