Potential from a ring of charge
To find the electric potential at point P above a ring of charge, first drop a perpendicular from P to the center of the ring, creating a right triangle. The distance from the ring elements to point P can be expressed using this geometry. The electric field E due to the ring is calculated as E = kQ*OP'/(R^2 + OP'^2)^(3/2). The potential gradient along the perpendicular is determined by integrating the electric field over the distance from the center to point P. This approach allows for the calculation of the potential at point P based on the charge distribution of the ring.
-EquinoX-
http://img15.imageshack.us/img15/3462/poth.th.jpg
How can I find the potential at the point p above?
I really have no idea where to start at
I'd suggest that you use geometry.
Drop a perpendicular to the plane of the ring. Call it P' The distance then is a right triangle that has one side constant, P-P'. Your dq element distances from P can then be determined by the distance expression of the elements of the ring in the x-y plane to P' and the other leg P-P'.
I don't quite understand what you mean.. please elaborate
Drop a perpendicular from p to the axis of the coil. Let PP' = x be the the perpendicular. Let O be the center of the coil and R be the radius of the coil. Electric field due to the coil having charge Q is given by
E = kQ*OP'/(R^2 + OP'^2)^3/2
The potential gradient along P'P is given by deltaV = E.dx = E*dx*cos(theta) = -E*dx*x/OP' .Substitute the value of E. Find the integration from x = 0 to x = x.
