Potential of a conducting sphere in a conducting shell
The discussion revolves around a problem involving a conducting sphere with charge Q inside a conducting shell with charge 2Q. Participants are tasked with finding the electric potential and energy associated with this configuration, while considering the implications of electric fields and potentials in different regions.
  • Participants explore the electric field in various regions and attempt to derive the electric potential based on these fields. Questions arise regarding the definition of energy in this context and the assumptions made about measuring potential from infinity. There is also discussion about the constancy of potential within conducting materials and the implications of potential differences.
The discussion is ongoing, with participants providing feedback on each other's calculations and clarifying concepts. Some guidance has been offered regarding the conservation of charge when connecting the sphere and shell with a conductive wire, and there is an exploration of recalculating fields and potentials based on new charge distributions.
Participants note potential typos in the original equations and the need for clarity regarding the reference point for electric potential. There is also mention of the implications of charge transfer between the sphere and shell, leading to questions about the resulting charge distribution and energy considerations.
razidan
A conducting sphere, radius R, charged with Q is inside a conducting shell (2R<r<3R) with charge 2Q. Find the electric potential and the energy.
[itex]\Phi =-\int_{r_1}^{r_2} \vec{E}\cdot\vec{dl}[/itex]
[itex]U=\int_{V}E^2dV[/itex]
I think i got it right, and I'm mostly looking for confirmation:
I started with calculating the field everywhere:
[itex] \vec{E} (r) =<br /> \begin{cases}<br /> 0 & \quad \text{if } \text{ r<R}\\<br /> \frac{kQ}{r^2} \hat{r} & \quad \text{if } \text{ R<r<2R}\\<br /> 0 & \quad \text{if } \text{ 2R<r<3R}\\<br /> \frac{3kQ}{r^2} \hat{r} & \quad \text{if } \text{ r>3R}\\<br /> \end{cases}[/itex]
this leads to:
[itex] \Phi (r) =<br /> \begin{cases}<br /> \frac{kQ}{2r} & \quad \text{if } \text{ r<R}\\<br /> \frac{3kQ}{3R}+\frac{kQ}{2R}-\frac{kQ}{r} \hat{r} & \quad \text{if } \text{ R<r<2R}\\<br /> \frac{3kQ}{3R} & \quad \text{if } \text{ 2R<r<3R}\\<br /> \frac{3kQ}{r} \hat{r} & \quad \text{if } \text{ r>3R}\\<br /> \end{cases}[/itex]
[itex]\text{and the energy is} \quad 14\pi\frac{k^2Q^2}{R}[/itex]
Thanks,
R
There are a couple things that I'm unclear about. What do you mean when you say 'energy'? Do you mean the potential energy of a particle far away from the sphere? This seems a bit unclear. Also, I'm assuming for the first part that you are measuring the potential difference from infinitely far away; there is no real meaning to an absolute electric potential, it all depends on where you take it in reference to. Is there any more information that came with the problem?
I don't know if this was a typo, but when you list the potential energy for r<R you list it as varying with radius r. That shouldn't be the case; the potential within a conducting body should always be constant. A conducting volume is a large equipotential region; the way you have it listed would give an electric field within the sphere of kQln(2r), which is obviously not true.
Hello and thanks for the response:
what I mean by energy is the electrostatics energy needed to construct such a system, by bringing infinitesimal amounts of charge, bit by bit from infinity.
and about "r" - it is indeed a typo... for some reason i cannot edit that post.
R
I agree with your fields but not your potentials. How did you arrive at them?
Thanks, missed a "-" sign:
[itex] \Phi (r) =<br /> \begin{cases}<br /> \frac{3kQ}{2R} & \quad \text{if } \text{ r<R}\\<br /> \frac{3kQ}{3R}-\frac{kQ}{2R}+\frac{kQ}{r} & \quad \text{if } \text{ R<r<2R}\\<br /> \frac{3kQ}{3R} & \quad \text{if } \text{ 2R<r<3R}\\<br /> \frac{3kQ}{r} & \quad \text{if } \text{ r>3R}\\<br /> \end{cases}[/itex]
A follow up question (given that the potential in my last response is correct):
The sphere and the thick shell are now connected with a conductive wire. what is the potential and energy now?
This part has me stumped. I know that now the sphere and the shell have the same potential because charged can transfer.
But I'm not sure what to do.
Thanks,
R
It was. Sorry, I omitted to confirm.
Right. What is conserved? What equations can you write relating the charges and the potentials?
I understand that the charge is being conserved.
[itex]Q_1 +Q_2 =3Q[/itex]
I'm not sure that writing this is correct, though:
[itex]\Phi(r<R)=\Phi(2R<r<3R) => \frac{3kQ_1}{2R} = \frac{3kQ_2}{3R}[/itex]
I'm not sure if this is correct because the numerical factors all came from the integration of the fields, before the charge was transferred...
Quite so, you cannot use those. So recalculate the fields and potentials in terms of two unknown charges.
Ok, I will try this, Thanks!
I have found that the charge on the inner sphere is now zero. Is that correct? If so, Is is because this configuration has a lower energy associated with it, and so the system "prefers" this configuration?
Yes.
haruspex said:
Yes.
Thank you very much!
