Finite Well Solutions: Understanding d and k in Potential Wells
The discussion centers on understanding the wave function for a finite potential well, specifically the form L Sin(kx + d). Participants explore the relationship between the phase constant d and the well's potential, noting that d appears to depend inversely on the potential. The value of k is derived from the energy of the particle and the potential well, with discussions on how to relate different forms of the wave function. A key point is that d can be expressed as arcTan(k/s), which aligns with boundary conditions. The conversation concludes with a resolution on the significance of d in the context of the wave function.
physicsjock
Hey,
I've been trying to work out how, for a finite well of high Vo and width L, the interior solution has the form L Sin(kx + d),
I see that if d=0 then the solution resembles an infinite well, so that implies d depends inversely on the wells potential. But I can't work out what d comes from, and why the constant at the front is the length of the well (why is the amplitude of the wave the length of the well)
d is just the phase of the wave, so does it represent the reflection of any particles which moved past the well?
Ive also been trying to work out what the k is, when I go through the process of finding the wave function inside I end up with (s/k)Asinkx + Acoskx after applying the boundary conditions.
where k2=2mE/\hbar^{2}
and s2=2m(Vo-E)/\hbar^{2}
i've been trying to work this out because the question also says that the solution inside the well should also satisfy
ka = n\pi - 2Sin^{-1}(\frac{k\hbar}{\sqrt{2mV_{o}}})
which makes me think the d resembles that arcsin the above equation
Anyone have any ideas?
It looks like you're trying to solve the time-independent Schrodinger equation, which should have been listed as a "Relevant Equation" in the homework template. It also puts this in the Advanced Physics category, so I'll move the thread there.
physicsjock said:
Hey,
I don't think the constant is simply L -- the units are wrong -- but at any rate it would be found by normalizing the wavefunction.
It represents the fact that the potential is not zero at the well boundary x=0. This is related to the fact that the potential is nonzero beyond the boundary as well, i.e. the particle's wavefunction penetrates beyond the boundary. I wouldn't really call that reflection though.
where a = ?
It's hard to tell exactly what you are stuck on. Is it just in trying to relate the two forms of solution you have given,
(s/k)A\sin kx + A\cos kx \ \small \text{ and } \normalsize \ B \sin(kx + d) \text{,}
to each other?
to each other?
Yea that's what I'm stuck on,
Sorry that ka = ... formula I wrote was from a set of notes where the the width of the well is a,
so a = L,
I've tried substituting kl into the interior solution, ψ(L)
where
ψ(x)=(s/k)Asinkx + Acoskx
so ψ(L)=(s/k)AsinkL + AcoskL
and ended up with
ψ(L)=-A cos(n\pi)
assuming that the k in that formula is the same as the k i posted before
Try using trig angle-sum identities on sin(kx+d). I'm pretty sure that will work out to a form that you can more easily equate with
(s/k)Asinkx+Acoskx​
so a = L,
Okay.
where
and ended up with
ψ(L)=-A cos(n\pi)
I'm not following you here, mainly because I can't do this in my head and don't have time right now to work it out on paper to verify what you are saying.
But, if you are satisfied with the "(s/k)Asinkx+Acoskx" form of the solution, we should probably just concentrate on seeing how "Sin(kx + d)" is equivalent. Will you also be needing to normalize the wavefunctions, and finding the energy eigenvalues, or are you good with how to do that?
Hey,
I worked it out, the d in the sign was just to compensate for the lack of cos in the solution,
I found the d was something like arcTan(k/s) and it was consistent with the boundaries and stuff,
Thanks for your help!
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
