Power, velocity and frictional resistance
The discussion revolves around calculating the frictional resistance of a car with a mass of 1365 kg and a 60 kW engine, achieving a maximum speed of 145 km/h. The initial calculation for frictional force yielded 149,205 N. For the second part, the maximum speed of the car on a 1 in 5 gradient was calculated, but the response highlighted that friction would not remain constant as speed changes. The conclusion emphasizes the need to reconsider the assumptions regarding friction in varying conditions.
Darth Frodo
(a) A car of mass 1365kg has 60kW engine and a max speed of 145km/hr. Find the frictional resistance.
(b) Calculate max speed of car up a gradient of 1 in 5 if Friction stays the same.
P = F.v
60000 = F (40.2m/s)
F = 149205 N
(b) P = netF . V
60000 = (1492.5 + mgsinθ)
θ = angle of inclination
60000 = [1492.5 + (1365)(9.8)(1/\sqrt{26})]V
v = 60000/4118.6 = 14056 m/s
Is this correct?
It looks good to me!
The question isn't quite right; friction will not remain the same as the speed changes.
