Power available vs Power required ?
  • Thread starter Thread starter SonOfGod
    Power
The discussion centers on the discrepancy between available power and required power for an aircraft at varying altitudes, specifically from sea level to 20,000 feet. The user, a performance and propulsion engineer, notes that their engine provides 2000 watts of power, while only 200 watts are required at 20,000 feet. Key factors affecting this include the efficiency of the propeller, which typically peaks at around 80%, and the impact of parasite drag that increases with airspeed. Understanding these elements is crucial for optimizing aircraft performance and ensuring accurate power calculations.
  • Basic understanding of aircraft propulsion systems
  • Knowledge of propeller efficiency and its impact on thrust
  • Familiarity with drag forces and their relationship with airspeed
  • Experience with power calculations in aerodynamics
  • Research propeller efficiency curves and their effects on thrust generation
  • Study the relationship between parasite drag and airspeed in aircraft design
  • Learn about power required calculations at different altitudes
  • Explore methods for optimizing engine performance in varying flight conditions
Aerospace engineers, performance analysts, and students in aerodynamics or propulsion systems will benefit from this discussion, particularly those focused on optimizing aircraft performance and understanding power dynamics at altitude.
SonOfGod
Hello everyone,
I am new here, came here to meet some experts and solve my problems :)
I am working on a project, as performance and propulsion engineer of the team (undergraduate). I have done everything that is there to do, but now stuck, i just hit a brick wall that will make my first class degree a second/third class :(
I am calculating the power available or thrust available at range of altitude starting from sea level up to 20,000 feet. I know how much horsepower or power my engine supplies me at a given altitude. But that seems to be extremely huge figure compared to the amount i need.
Example:
AT 20,000 feet altitude
Engine power available = 2000 watts, power required = 200 watts
The propeller that I am using , is it the source of the problem ? Will it scale down the engine power by huge amounts when converting it to thrust ? How do i find it out ?
Any help will be appreciated a lot since my whole degree depends on this report :(
THANKS
Hmm, you're missing some info. What's the maximum level airspeed you want the plane to fly at altitude? Parasite drag increases with the square of velocity which means power required increases the faster you go. 2ndly if this is a prop aircraft propeller efficiency also varies with velocity topping out at about 80% typically meaning you get a max of about 80% of your engine power output at peak prop efficiency.
  • · Replies 69 ·
18K
