Power dissipation due to temperature change
The discussion revolves around calculating power dissipation in a heater when the wire temperature changes from 800°C to 200°C. The initial power dissipation is 500W at 110V, leading to a calculated resistance of 24.2 ohms. Using the resistivity formula, the resistance at 200°C is found to be 18.392 ohms, which leads to a power dissipation calculation of approximately 610W. There is uncertainty about the correctness of the answer provided, prompting a suggestion to verify with the lecturer. The conversation highlights the importance of understanding the linear dependence of resistance on temperature for accurate calculations.
KingBigness
Heater dissipates 500W when applied potential diference is 110V and wire is 800C. How much power would it dissipate if the wire temperature were held at 200C?
a=4.0e-4
p=V^2/R
Rf=R0(1+a(T-T0) where R is resistance after temp change
R0 is initial resistance
a is coefficient of resistivity
P=V^2/R
R=V^2/P
R=110^2/500
R=24.2
Rf=24.2(1+4.0e-4(200-800)
Rf=18.392
P=110^2/18.392
I'm sure it is just a silly mistake I have done somewhere only just started electronics today after a 2 month university break!
Answer should be 610W
Thanks for any help
The method is correct and the calculation is correct. Unless you are expected to use something other than a linear dependence of resistance on temperature (which would be more realistic for a temperature change as big as 400 degrees), the correct answer should be what you have. How do you know the correct answer is 610W?
Cheers for the reply, that is what the answer says but it has been known to be wrong sometimes.
I'll double check with my lecturer, he my have just wrote the wrong answer down.
Thanks again
