What is the average power if the resistance R is doubled in an AC circuit?
Doubling the resistance in an AC circuit while keeping the applied voltage constant results in a new average power of 2.0 W, as confirmed by using the equation P_{rms} = V_{rms}^2/R. The confusion arises from using the equation P_{rms} = I_{rms}^2R, which is not applicable here since the current changes with the new resistance. It's important to assume constant voltage in these scenarios, as most power sources maintain a steady voltage with variable current. Therefore, the correct approach is to use the voltage-based equation for accurate power calculation.
Coop
The average power dissipated by a resistor is 4.0 W. What is the average power if the resistance R is doubled?
P_{rms}=I_{rms}^2R=I_{rms}V_{rms}=\frac{V_{rms}^2}{R}
I am told the answer is 2.0 W. But here's what I am confused about...it is valid to use all of the power equations above for this problem, correct? Well if I use
P_{rms}=I_{rms}^2R I get the new average power to be 8.0 W.
But if I use the
P_{rms}=\frac{V_{rms}^2}{R} I get the new average power to be 2.0 W.
How do I know which equation to use?
Thanks.
The problem assumes the applied voltage is the same. You should always assume that unless otherwise stated because most power sources produce constant voltage and variable current (assuming you didn't do something crazy such as a short-circuit). So, when you replace a resistor with a different resistor, the current changes but the applied voltage doesn't, hence the second equation gives the correct answer.
Likes 1 person
So I can't use I^2R, because by definition the current would also be a different value for a new R? But we know the voltage will stay the same for a new R, so we can use V^2/R?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
