How Much Power is Lost in a Copper Wire in a Series Circuit?
In a series circuit with a 200m long copper wire and a 10Ω resistor connected to a 50V supply, the resistance of the wire was calculated using the formula R = ρL/A, yielding a wire resistance of approximately 2.333Ω. The total current in the circuit was determined to be 21.36A, leading to a power loss calculation for the wire. The initial power loss estimate was 1068.37W, but corrections were made to account for the series resistor and more accurate resistance values. The final power loss in the wire was confirmed to be approximately 1067.62W. Accurate calculations and consideration of all circuit components are crucial for precise results.
chawki
A 200m long copper wire, with cross section area of 1.5mm2, is connected with a 10Ω resistor in a series circuit, and the supply voltage is 50V.
Find the power loss in the copper wire, when ρ=0.0175 Ωmm2/m
R=*L/A
P=V2/R
P=502/(0.0175*(200/1.5))
P=1068.37 Watt.
R=*L/A
P=V2/R
P=1068.37 Watt.
The voltage supply is across the wire AND the resistor (they are in series), not just the wire.
yeah i think i made a mistake :/ but we don't have I
Then you need to find out what the current, I, is.
What is the resistance of the copper wire?
I=50/2.34=21.36Amperes
P=2.34*(21.36)2
P=1067.62 watt
somehow it looks the same answer as the one posted in post #1
P=2.34*(21.36)2
P=1067.62 watt
You still haven't accounted for the 10 Ω resistance that's in series with the wire.
Also, your wire resistance should be 2.333 Ω to three decimals, not 2.34; I know it's being picky, but early rounding of intermediate results can muck up final results when there are multiple steps. It's good to get into the habit of keeping a few extra digits of accuracy in intermediate results, and round final results.
