Power Supply Caps: Why Do They Have High Voltage?
Power supplies, particularly in computers, utilize high voltage capacitors due to the operation of switching power supplies that convert household voltage into high frequency voltage. This conversion process can induce high voltage in the high frequency transformer, necessitating the use of capacitors that can withstand these elevated voltages. The design ensures stability and efficiency in voltage regulation. High voltage capacitors are essential for maintaining performance and safety in power supply systems. Understanding this is crucial for anyone working with or designing computer power supplies.
david90
why do power supplies like computer power supplies have high voltage caps?
Today's computers use switching power supplies which take a house hold voltage and convert it to high frequency voltage which is then down converted to a lower voltage. But during this process, high voltage may be induced in the high frequency transformer, hence you need high voltage caps.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
